code to button switch on LCD
Nebbiolo
PostPosted: Sun Jun 09, 2019 6:18 pm     Reply with quote
Hi! Can anyone help with a solution to my code? I'm new about C language but, I'm learning a little every day. I wrote this code to make a button when pressed, turn on a LED and send to LCD the status of each LED. But I can't make this work properly!
That is what I would like to do:
When press button at RB3, turn on the LED A0 and show at LCD: Door 01,
and when I press again the RB3, turn the other LED A1 and show at LCD: Door 02.
Someone can tell me how to write correctly this code?
       if(input(PIN_B3) == 0){
       printf(lcd_putc,"\fDOOR 01");
       printf(lcd_putc,"\fDOOR 02");
       output_toggle(PIN_A0);
       output_toggle(PIN_A1);
Thank you so much for any help!
PostPosted: Sun Jun 09, 2019 9:07 pm     Reply with quote
Two methods to read buttons are given here:
http://www.ccsinfo.com/forum/viewtopic.php?t=58066&start=7
