Conversion Library
José Aparecido
Conversion Library
PostPosted: Thu Jun 06, 2019 5:16 pm     Reply with quote
Hi, I'm developing a project using a PIC18F4550 microcontroller and an LM044L LCD display. I need a library that converts hexadecimal values (int) to decimals.
Then I will display these decimal values on the LCD display.
Does anyone know where I can find such a library? Or how can I convert the values? Thanks.
PostPosted: Thu Jun 06, 2019 6:29 pm     Reply with quote
It's all in the CCS manual, in the section on printf.
Example:
http://www.ccsinfo.com/forum/viewtopic.php?t=42090&start=1
CCS manual:
https://www.ccsinfo.com/downloads/ccs_c_manual.pdf
The printf section starts on page 276.
PostPosted: Fri Jun 07, 2019 4:23 am     Reply with quote
just a helpful hint..
... while your project is open, pressing F11 will display the CCS Manual, when using MPLAB.
it's always there when I'm cutting code...
Jay
PostPosted: Fri Jun 07, 2019 8:04 am     Reply with quote
and just as a further comment to this, since it is not said where these numbers
are actually coming 'from', if they are hexadecimal, then 'atoi', is the function
to convert ASCII to an integer.
