Tommy Liu Guest
| printf(), lcd_putc() and ROM space |
Posted: Mon Jun 23, 2003 1:18 am |
The following:
printf(lcd_putc ,"\fMessage\n");
can be replaced by the following:
lcd_putc("\fMessage\n");
to save ROM space.
Can the following statements be represented by lcd_putc() or another format to save ROM space?
printf(lcd_putc,"\%4.3fV(ADC=\%4lu)", volt, ADC_value);
printf(lcd_putc,"\fFAILED at pos=\%u\n", pos);
Thanks in advance.
RF
___________________________
Original Post ID: 144515462 |
| Re: printf(), lcd_putc() and ROM space |
Posted: Mon Jun 23, 2003 5:39 pm |
:=Can the following statements be represented by lcd_putc() or another format to save ROM space?
:= printf(lcd_putc,"\%4.3fV(ADC=\%4lu)", volt, ADC_value);
:= printf(lcd_putc,"\fFAILED at pos=\%u\n", pos);
In the code above, the printf is doing a conversion from
the float and "unsigned long" data types to ASCII.
The lcd_putc() function can not do this conversion.
Original Post ID: 144515495 |
Tommy Liu Guest
Posted: Tue Jun 24, 2003 1:20 am |
:=:=Can the following statements be represented by lcd_putc() or another format to save ROM space?
:=:= printf(lcd_putc,"\%4.3fV(ADC=\%4lu)", volt, ADC_value);
:=:= printf(lcd_putc,"\fFAILED at pos=\%u\n", pos);
:=In the code above, the printf is doing a conversion from
:=the float and "unsigned long" data types to ASCII.
:=The lcd_putc() function can not do this conversion.
Thanks for your explanation. It is what I thought as well.
Tommy
Original Post ID: 144515506 |
