TQFP 80 18F8720 adapter
nilsener
PostPosted: Mon Jun 23, 2003 10:16 am     Reply with quote
Dear,
we want to use 18F8720 for our new design but we ask us how to replace the chip if it fails during the software development. Does someone know where to buy a TQFP 80 to TQFP 80 adapter that can be soldered onto the smd pads and then plug in the TQFP 80 Device ?
Thanks for helping
best regards
nilsener
Original Post ID: 144515471
john cutler
Re: TQFP 80 18F8720 adapter
PostPosted: Mon Jun 23, 2003 11:25 am     Reply with quote
I don't know if they make one with that many pins, but I know it will cost a lot more than a $40 CCS board.
JC
Original Post ID: 144515476
john cutler
PostPosted: Mon Jun 23, 2003 11:33 am     Reply with quote
You might try these guys...I spoke to them and they are very helpful - they will even let you send them a few chips and they'll mount them to their adapters, which is what I need - I'm still in dip land.
jc
Original Post ID: 144515477
Douglas Kennedy
PostPosted: Mon Jun 23, 2003 12:27 pm     Reply with quote
This chip may have been destined to come out in a PLCC84 package. In fact Microchips picstart notes for this chip referenced a plcc84 pinout instead of the 80qfp. It maybe another case of Microchip marketing interfering with engineering development.We are lucky the 8720 wasn't a circular chip to match the ICD2 hockey puck concept.
I drew up a circuit to take the pins out to a square of four 2x20 .1" pins ....sent it to www.expresspcb.com and for $62 got back six headers. On my breadboard or target board I have the square( 4 sides ) 2x20 IDC type sockets to receive the header board. I find I really need to be able to unplug these pesky chips. They are much more prone to fail than their sturdier DIP cousins. A crossed trace or just about any mistake and a 18F8720 is toast. Microchip really should have come out with a robust package for developers
Original Post ID: 144515479
john cutler
PostPosted: Mon Jun 23, 2003 2:50 pm     Reply with quote
I just don't see well enough (or have a steady enough hand) to solder things that small! Nor do I have the $$$ for a microcope, special irons, hot air etc.
Am I to becme obsolete because of miniaturization? I always thought it wold be Azheimers Smile
Original Post ID: 144515482
Douglas Kennedy
PostPosted: Mon Jun 23, 2003 3:35 pm     Reply with quote
:=I just don't see well enough (or have a steady enough hand) to solder things that small! Nor do I have the $$$ for a microcope, special irons, hot air etc.
:=Am I to becme obsolete because of miniaturization? I always thought it wold be Azheimers <img src="http://www.ccsinfo.com/pix/forum/smile.gif" border="0">
Sadly since Microchip doesn't want to help us much , many will just avoid developing for this chip.
Since I needed the extra program ROM space here is what I did.
without using a hot air rework station.
Position the pesky chip and gingerly tack solder a pin at each corner. (This keeps it from moving when placing it in the toaster oven... and yes you will need magnifying glasses)
Mark the pcb with a color changing wax pen or cut a small piece of solder wire and place on a truhole. Place board and chip in an old toaster oven and wait for the color to change ( or the small piece of solder wire to melt) indicating the solder has melted under the 8720 chip pins and reflowed
turn off the toaster oven and let the board cool down
Now so no one risks getting lead poisoning don't use the oven for toast or anything else.
Original Post ID: 144515486
John Yaron
PostPosted: Mon Jun 23, 2003 5:24 pm     Reply with quote
:=Dear,
:=we want to use 18F8720 for our new design but we ask us how to replace the chip if it fails during the software development. Does someone know where to buy a TQFP 80 to TQFP 80 adapter that can be soldered onto the smd pads and then plug in the TQFP 80 Device ?
:=Thanks for helping
:=best regards
:=nilsener
I was unable to find a socket.
The best I came up with is pricy consisting of:
PACE MBT250 rework station
PACE Pik & Paste 100
of course, microscope required also.. picked up a
MicroMaster on EBAY for $500
But, laying down a bead of solder paste, placing
the chip in it and hot air jet reflowing it
gives superior results and is quite easy once
you get the hang of it.... so much to the point
that I don't even do thru-hole anymore...even
on my in-house test and programming boards
Arm/Elbow rests are achieved my putting the scope
in the recessed knee of 2 table's at 90 degree angles
I've built some protoypes that look just like a
production board.
0.5mm pitch 18F8720's are even becoming
ho-hum to install/remove anymore.
The only trick is keeping the discrete/chip from moving
due to the hot air flow/pressure, but, the variable
flow valve solves that.
Like you say... I don't want to obsolete myself, so,
I figure ...pay the piper
It's worth it in the long run.
Original Post ID: 144515494
nilsener
PostPosted: Wed Jun 25, 2003 12:43 am     Reply with quote
<font face="Courier New" size=-1>Dear Douglas,
I have searched for the picstart notes on microchips's website but I did not found it. Please can you be so kind to tell me where to find this document ?
Thanks a lot and
best regards
nilsener
:=This chip may have been destined to come out in a PLCC84 package. In fact Microchips picstart notes for this chip referenced a plcc84 pinout instead of the 80qfp. It maybe another case of Microchip marketing interfering with engineering development.We are lucky the 8720 wasn't a circular chip to match the ICD2 hockey puck concept.
:=I drew up a circuit to take the pins out to a square of four 2x20 .1" pins ....sent it to www.expresspcb.com and for $62 got back six headers. On my breadboard or target board I have the square( 4 sides ) 2x20 IDC type sockets to receive the header board. I find I really need to be able to unplug these pesky chips. They are much more prone to fail than their sturdier DIP cousins. A crossed trace or just about any mistake and a 18F8720 is toast. Microchip really should have come out with a robust package for developers</font>
Original Post ID: 144515546
Douglas Kennedy
PostPosted: Wed Jun 25, 2003 4:16 pm     Reply with quote
I pointed out to Microchip that the documnetation was wrong wrt to the PLCC84 pinouts for the 18F8720 or they forgot to make that package. The correspondence is in the MICROchip picstart plus forum under 18F8720
Original Post ID: 144515570
Tony Gruber
PostPosted: Thu Jun 26, 2003 9:49 am     Reply with quote
Microchip has an XLT80PT emulator adapter (list $125) that solders to the pads on your board. A custom interface board could be made that carries 18F8720 and has headers that plug onto the emulator adapter. When the chip fails this interface board would unplugged and discarded.
:=Dear,
:=best regards
:=nilsener
Original Post ID: 144515577
