18F87K22 INT0 firing random.
beaker404
PostPosted: Fri May 10, 2019 9:48 am     Reply with quote
Throwing this out to the group. Not really a programming question, but perhaps it is if it is fuse disable issue.
I am using INT0 on PIN_B0 as a trigger for firing off my ACQ loop section. Pretty standard stuff, and I have done it allot on 16F876 platforms. Trigger circuit is simple, interrupt line is pulled up with a 10K resistor to 5VDC. Same 5VDC used to power the PIC. INT0 line is grounded to trip the interrupt.
It will trip every once in a while by itself and the scope shows a sharp dip to ground then a typical rise curve back to 5V. I thought it was my switch, but do not have anything connected external to the PCB and it still does it. Anyone got thoughts on this? Is it a fuse that is not set right? here is some code snippets.
#device PIC18f87k22
#include <18F87K22.h>
#device ADC=12
#fuses HSH, NOWDT, PUT, NOBROWNOUT, NOMCLR
#use delay(crystal=15M, clock=60M)
#use rs232(UART1, baud=57600, STREAM=SERIAL, errors)
#USE SPI(MASTER, MODE=0, SPI1, STREAM=SPI,FORCE_HW)
void init_hardware() {
// Initializes all hardware.
    set_timer1(64845L);                                  // 20KHz rollover rate
   output_high(SRAM_CS1);
   output_high(SRAM_CS2);
   output_high(SRAM_CS3);                                // SRAM and EEPROM Select lines
   output_high(EEPROM_CS);
   output_low(LED_BLINK);
   output_high(SRAM_HOLD);
   setup_adc(ADC_CLOCK_DIV_32);          // set up ADC
   setup_adc_ports(sAN0|VSS_VDD);                        // only AN0 is analog port with range of 0 - 5VDC
    ext_int_edge(H_TO_L);      // init interrupt triggering for button press
    enable_interrupts(INT_EXT);// turn on interrupts
    enable_interrupts(INT_RDA);
}  // end init_hardware()
I really hate to put allot of capacitance on this line as my trigger needs to be fast.
18F87K22 running 60MHz
CCS 5.064
MPLAB 8.91
Windows 10
beaker404
PostPosted: Fri May 10, 2019 10:13 am     Reply with quote
one other bit of information, I am powering my board off of the PICKIT3 at 5V
PostPosted: Fri May 10, 2019 10:33 am     Reply with quote
Pickit 3 manual says:
3.4.4 Powering the Target
These are configuration essentials:
• When using the USB connection, PICkit 3 can be powered from the PC
but it can only provide a limited amount of current, up to 30 mA, at
VDD from 1.8-5V to a small target board.
The desired method is for the target to provide VDD since it can
provide a higher current. The additional benefit is that plug-and-play
target detection facility is inherited, i.e., MPLAB IDE will let you know in
the Output window when it has detected the target and has detected the device.
Get an external power supply for your board, and also, set all unused i/o
pins to a logic low level. This will reduce noise injected into the PIC
through floating i/o pins.
PostPosted: Fri May 10, 2019 12:22 pm     Reply with quote
and remember at 60MHz, the pulse needed to trigger the interrupt will
be shorter than on the older PIC, and at that speed the load on the
PicKit will be higher than it is designed to deliver.
