INT_EXT1_H2L
soonc
INT_EXT1_H2L
PostPosted: Thu Jan 17, 2019 4:16 pm     Reply with quote
Signal at PIN_B4 is high and goes low to 10mS signal is clean no bounce.
Vdd is 3.3V
The chip does not wake up !
I'm a little confused about GLOBAL interrupt. Should it be disabled or enabled !
The #INT_EXT1 ISR is needed as the code locks without it.
Any help is welcomed.
#include <18F47K42.h>
#device ADC = 8
#use delay(clock = 12000000, crystal = 12000000)
#FUSES NOWDT
#FUSES HS // more fuses from a working project
#pin_select INT1=PIN_B4
#INT_EXT1
void RTC_Alarm_isr(void)
   // do nothing
   // is this needed ?  clear_interrupt(INT_EXT1_H2L);
   disable_interrupts(GLOBAL); // only want INT_EXT1_H2L to wake up the chip
I tried enable_interrupts(GLOBAL); // did not work either
   enable_interrupts(INT_EXT1_H2L);  // Hi to Lo
   sleep(SLEEP_FULL); // Wait for RTC Alarm pulse to wake up cpu
   delay_cycles(1);
   while(1)  // never gets here
     output_toggle(PIN_C5);
PostPosted: Fri Jan 18, 2019 2:04 am     Reply with quote
GLOBAL needs to be enabled.
This is the 'master gate'. Allows _all_ enabled interrupts to be
turned on/off. To use an interrupt, it must be enabled, and GLOBAL
must also be enabled.
Then when an interrupt occurs, it's handler will be called. The handler
has to exist, or the code will go off into nowhere.
Then there is an issue.
With an interrupt, there is the 'event' that triggers it, and the flag
that gets set. Clearing an interrupt resets the flag, and this is done
automatically for you be the compiler, so you don't need an extra clear
in the routine. However this does not reset the 'event'. In this case
the 'event', is the act of PortB not matching what has last been
read from PortB. On and interrupt on change, the
handler _must_ read the port, to reset the event, or the flag cannot
be cleared (since the event is set, it'll keep resetting the flag). If this
is not done, the code can't actually leave the interrupt handler - it'll
be called for ever.
So, GLOBAL needs to be enabled.
Handler must exist.
Handler must read the input pin.
