garyatpt
				| [Bug] CCS 5.081 Interrupt-Vector-Table Bug for PIC18F27K42 |
				 Posted: Tue Oct 02, 2018 12:28 am     |
				Dear all,
step1: Disabled interrupt vector table (IVT) using (//#device vector_ints)
       -->When input 'uart2_cmd' from UART2 RX interrupts, everything work fine.
step2: Enabled interrupt vector table (IVT) using (#device vector_ints)
       -->When input 'uart2_cmd' from UART2 RX interrupts, then mcu will "Stop" work.
For CCS 5.080, step1 & step2 all work fine.
//ccs 5.081
//IVT_demo (Interrupt Vector Table demo)
#include <18F27K42.h>
// Disabled interrupt vector table (IVT) <---work fine
// Enabled interrupt vector table (IVT) <---work error
#device vector_ints
#fuses NOWDT
#use delay(internal=64MHz)
#use fast_io(A)
#pin_select U1TX=PIN_C1
#pin_select U1RX=PIN_C0
#use rs232(baud=9600,  UART1, bits=8, stop=1, parity=N, stream=STREAM_UART1, errors)
#pin_select U2TX=PIN_C6
#pin_select U2RX=PIN_C7
#use rs232(baud=9600,  UART2, bits=8, stop=1, parity=N, stream=STREAM_UART2, errors)
#byte   LAT_A   =   0x3FBA
#bit    TP      =   LAT_A.0    //O
int8 uart2_cmd;
//// timer2 interrupts  (200us)
#int_timer2
void timer2_isr(void)
    TP=!TP;
// UART2 RX interrupts
// Purpose:   Interrupt service routine for handling incoming serial data
#int_rda2
void incomming_serial_2()
    uart2_cmd=fgetc(STREAM_UART2);
int8 cmd;
    set_tris_a(0b00000000);     //RA0-->TP ouptup monitor
    TP=0;
    //------------------timer2 setting
    setup_timer_2(T2_DIV_BY_64 | T4_CLK_HFINTRC, 199, 1);   //200us
    set_timer2(0);
    enable_interrupts(INT_TIMER2);                          //enable TIMER2 interrupts
    //------------------enable UART2 RX interrupts
    enable_interrupts(INT_RDA2);
    //------------------global interrupts
    //UART1
    fprintf(STREAM_UART1, "\r\nIVT_demo - %s\r\n", getenv("DEVICE"));
    do
        //UART1
        fprintf(STREAM_UART1, "\r\nInput R from UART2: ");
        uart2_cmd=0;
        do
            //Get cmd from (UART2)
            cmd = toupper(uart2_cmd);
        } while((cmd != 'R'));
        //UART1
        fputc(cmd, STREAM_UART1);
        fprintf(STREAM_UART1, "\r\n------------- ");
        fprintf(STREAM_UART1, "\r\nOk-->R ");
        fprintf(STREAM_UART1, "\r\n");
    } while(TRUE);
