Push button 16f877a
Ventouza
Push button 16f877a
PostPosted: Mon Feb 04, 2019 3:31 am     Reply with quote
Hi there,
i have written a simple program, when i press the button a led must be on!
But it doesn't, what am i doing wrong? I use the 5.008 version.
Here is the code:
#define btn1          PIN_A0
#define test          PIN_C1
#include <16F877A.h>
#use delay(clock = 20MHz)
  output_drive(test);
  output_low(test);
  output_float(btn1);
  while(true)
   if(input(btn1==0))
   output_high(test);
   else output_low(test);
The button is connected with an external pull up 10k resistor.
PostPosted: Mon Feb 04, 2019 3:33 am     Reply with quote
One very major but simple syntax error:
if(input(btn1==0))
Needs to be:
if(input(btn1)==0)
Currently it is trying to input from a pin defined by the logical result of
comparing btn1, with the value 0....
Ventouza
PostPosted: Mon Feb 04, 2019 4:21 am     Reply with quote
Thanks a lot Ttelmah!
