How to run my init code before ccs init code ?
drolleman
PostPosted: Sat Sep 01, 2018 8:54 pm     Reply with quote
Before ccs initializes things like the uart I want my init code to run first. How do I do this?
What I need to do is to set outputs as quick as possible.
thx David
PostPosted: Sat Sep 01, 2018 9:58 pm     Reply with quote
See the items in bold below:
#include <18F46K22.h>
#device NO_DIGITAL_INIT
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOPBADEN
#use delay(clock=4M)
#use rs232(baud=9600, UART1, ERRORS, NOINIT)
while(TRUE);
These are described in the CCS manual:
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf
drolleman
PostPosted: Sat Sep 01, 2018 11:20 pm     Reply with quote
Thank you.
It still uses 4, but I can live with that.
