DS1338 RTC driver
Post new topic   Reply to topic    CCS Forum Index -> Code Library
DS1338 RTC driver
PostPosted: Sat Apr 11, 2020 7:59 am     Reply with quote
////                               DS1338.C                           ////
////                     Driver for Real Time Clock                   ////
////  rtc_init()                                   Call after power up////
////  rtc_set_datetime(day,mth,year,dow,hour,min)  Set the date/time  ////
////  rtc_get_date(day,mth,year,dow)               Get the date       ////
////  rtc_get_time(hr,min,sec)                     Get the time       ////
////  rtc_write_nvr(address,data)                  Write to NVR       ////
////  data = rtc_read_nvr(address)                 Read from NVR      ////
////  get_bcd(data)                              Convert data to BCD  ////
////  rm_bcd(data)                               Convert data to int  ////
#define DSADDR 0xD0
#define DSRDADDR 0xD1
#define DS1338_SEC      0
#define DS1338_MIN      1
#define DS1338_HR       2
#define DS1338_DAY      3
#define DS1338_DATE     4
#define DS1338_MONTH    5
#define DS1338_YR       6
#define DS1338_CONTROL  7
unsigned int8 read_DS1338(unsigned int8 address)
   unsigned int8 result;
   i2c_start(I2CBUS);
   i2c_write(I2CBUS, DSADDR);
   i2c_write(I2CBUS, address);
   i2c_start(I2CBUS);
   i2c_write(I2CBUS, DSRDADDR);
   result = i2c_read(I2CBUS, 0);
   i2c_stop(I2CBUS);
   return(result);
void write_DS1338(unsigned int8 address, unsigned int8 data)
   i2c_start(I2CBUS);
   i2c_write(I2CBUS, data);
   i2c_stop(I2CBUS);
void rtc_init()
   unsigned int8 data;
   data = read_DS1338(DS1338_SEC);
   //if (bit_test(data,7)==0) //test if chip was alive
   //   rtc_live=TRUE;
   data &= 0x7F;
   i2c_start(I2CBUS);
   i2c_write(I2CBUS, DS1338_SEC);
   i2c_start(I2CBUS);
   i2c_write(I2CBUS, DS1338_CONTROL);
   i2c_write(I2CBUS, 0x10); //0x90 should give 1Hz 0xB0 does not reset OSC stopped flag
   i2c_stop(I2CBUS);
unsigned int8 get_bcd(unsigned int8 data)
   unsigned int8 nibh;
   unsigned int8 nibl;
   nibh=data/10;
   nibl=data-(nibh*10);
   return((nibh<<4)|nibl);
unsigned int8 rm_bcd(unsigned int8 data)
   unsigned int8 i;
   i=data;
   data=(i>>4)*10;
   data=data+(i&0x0F);
   return data;
void rtc_set_datetime(unsigned int8 day, unsigned int8 mth, unsigned int8 year, unsigned int8 dow, unsigned int8 hr, unsigned int8 min)
   i2c_start(I2CBUS);
   i2c_write(I2CBUS, 0x00);
   i2c_write(I2CBUS, get_bcd(min));
   i2c_write(I2CBUS, get_bcd(hr));
   i2c_write(I2CBUS, get_bcd(dow));
   i2c_write(I2CBUS, get_bcd(day));
   i2c_write(I2CBUS, get_bcd(mth));
   i2c_write(I2CBUS, get_bcd(year));
   i2c_stop();
void rtc_get_date(unsigned int8 &date, unsigned int8 &mth, unsigned int8 &year, unsigned int8 &dow)
   date = rm_bcd(read_DS1338(DS1338_DATE));
   mth = rm_bcd(read_DS1338(DS1338_MONTH));
   year = rm_bcd(read_DS1338(DS1338_YR));
   dow = rm_bcd(read_DS1338(DS1338_DAY));
void rtc_get_time(unsigned int8 &hr, unsigned int8 &min, unsigned int8 &sec)
   hr = rm_bcd(read_DS1338(DS1338_HR));
   min = rm_bcd(read_DS1338(DS1338_MIN));
   sec = rm_bcd(read_DS1338(DS1338_SEC));
void rtc_write_nvr(unsigned int8 address, unsigned int8 data)
   write_DS1338(address, data);
unsigned int8 rtc_read_nvr(unsigned int8 address)
   return(read_DS1338(address));
Driver for the DS1338 RTC module. Just a slight 'tweak' of the other
drivers for the Maxim RTC's
ertansuluagac
PostPosted: Sat Apr 11, 2020 8:04 am     Reply with quote
ccs c already exists in the driver folder. It is not very different from it. I think they both work.
Es
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
