mabedin000
| Unknown keyword #FUSES "BORV22" |
Posted: Wed Aug 30, 2023 7:57 am |
I only have this error in my code, I am not sure how to eliminate this error. When I hide BORV22, it shows no ROM available. Using PIC18F24k22
Can someone help me to figure out the problem? Thank you |
dyeatman
Posted: Wed Aug 30, 2023 8:12 am |
What is the compiler version?
Also, post your lines of code starting from the first (device declaration) to the oscillator frequency (#use delay) line that includes the fuses. _________________ Google and Forum Search are some of your best tools!!!! |
mabedin000
Posted: Wed Aug 30, 2023 8:16 am |
Compiler version 4.14
#include "18f24k22.h"
#include "globals.h"
// Compiler Options
#ifndef PROGRAMMICRO
#device icd=TRUE
#device ADC=8
#use delay(clock = 8000000)
#use fast_io(a)
#use fast_io(b)
#use fast_io(c)
// Configuration Bits:
#ifdef PROGRAMMICRO
#fuses NODEBUG
#fuses WDT
#fuses WDT1024
#fuses PUT
#else
#fuses DEBUG
#fuses NOWDT
#fuses NOPUT
// Fuses: LP,XT,HSH,HSM,ECH,ECH_IO,RC,RC_IO,INTRC_IO,INTRC,ECM,ECM_IO
// Fuses: ECL,ECL_IO,NOPLLEN,PLLEN,PRIMARY_SW,PRIMARY,NOFCMEN,FCMEN
// Fuses: NOIESO,IESO
#fuses INTRC,NOPLLEN,PRIMARY,NOFCMEN,NOIESO
// Fuses: PUT,NOPUT,NOBROWNOUT,BROWNOUT_SW,BROWNOUT_NOSL
// Fuses: BROWNOUT,BORV29,BORV25,BORV22,BORV19
#fuses BROWNOUT,BORV22
// Fuses: NOWDT,WDT_NOSLEEP
// Fuses: WDT_SW,WDT,WDT1,WDT2,WDT4,WDT8,WDT16,WDT32,WDT64,WDT128
// Fuses: WDT256,WDT512,WDT1024,WDT2048,WDT4096,WDT8192,WDT16384
// Fuses: WDT32768
// Fuses: CCP2B3,CCP2C1,NOPBADEN,PBADEN,CCP3C6,CCP3B5
// Fuses: NOHFOFST,HFOFST,TIMER3B5,TIMER3C0,CCP2C0,CCP2B5,NOMCLR,MCLR
#fuses NOPBADEN,CCP2C1,NOHFOFST,TIMER3C0,CCP2C0,MCLR
// Fuses: NOSTVREN,STVREN,NOLVP,LVP,NOXINST,XINST,DEBUG,NODEBUG
// Fuses: PROTECT,NOPROTECT,CPB,NOCPB,CPD,NOCPD,WRT,NOWRT,WRTC,NOWRTC
// Fuses: WRTB,NOWRTB,WRTD,NOWRTD,EBTR,NOEBTR,EBTRB,NOEBTRB
#fuses STVREN,NOLVP,NOXINST,NOPROTECT,NOCPB,NOCPD,NOWRT,NOWRTC,NOWRTB,NOWRTD
#fuses NOEBTR,NOEBTRB |
gaugeguy
Posted: Wed Aug 30, 2023 8:39 am |
| The oldest compiler that I have kept is 4.132 from 2012. I doubt that version 4.14 would have had support for the PIC18F k22 series. |
mabedin000
Posted: Wed Aug 30, 2023 8:44 am |
I think you are right.
PCD file is from 6/9/2011. Can you tell me what version I should use to make it work and where I can find it?
I have tried 5.015 version still had ROM issue. |
dyeatman
Posted: Wed Aug 30, 2023 8:55 am |
BTW, fuses should always come close to or right after the device declaration
(first line). They can affect many things. _________________ Google and Forum Search are some of your best tools!!!! |
gaugeguy
Posted: Wed Aug 30, 2023 9:24 am |
| Is this old code that you are trying to maintain or are you writing your own new code? |
mabedin000
Posted: Wed Aug 30, 2023 10:25 am |
Yes, it is old code. I am trying to modify it to reduce work but doesn't work. I think I need to move everything to new version complier to rewrite again. Again I don't have a lot of knowledge of PIC, I only worked with Arduino. Declaring all those variables, pins for PIC and fuses again from the beginning would be tough job for me.
Is there any simple way I can input C source file to the new version of CCS and It would define its headers and necessary files by itself for a chosen PIC?
And do some easy modification to fix it. |
