art
Exit for loop |
Posted: Fri Jun 02, 2017 2:06 am |
Hi ,
I'm trying to exit for loop using push button. However my code did not work as i plan.
I need it to give result as below:
0
1
2
3
0
1
2
3
art "when I push button"
However, my code output is:
0
1
2
3
art
0
1
2
3
art
Please show me how to do it.Here is my code
#include <18F4550.h>
#fuses HSPLL,NOWDT,PROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,ERRORS)
#include <string.h>
#include <input.c>
#include <stdio.h>
#include <stdlib.h>
#include <usb_cdc.h>
char c;
int i ,r;
unsigned char d;
unsigned char key;
usb_init_cs();
while (TRUE)
usb_task();
if (usb_cdc_kbhit())
c=usb_cdc_getc();
if (c=='\n') {putc('\r'); putc('\n');}
if (c=='\r') {putc('\r'); putc('\n');}
while(true)
ART:
d = usb_cdc_getc();
if(d=='A') // push A
while (key!=32) // push SPACE BAR to stop
if(usb_cdc_kbhit())
{key=usb_cdc_getc();}
init_ext_eeprom();
for(y=0;y<=1000;y++)
printf(usb_cdc_putc,"%d\r" y);
printf(usb_cdc_putc,"%d\r" y+1);
printf(usb_cdc_putc,"%d\r" y+2);
printf(usb_cdc_putc,"%d\r" y+3);
if(input(PIN_B6)); //push button
printf(usb_cdc_putc,"art\r");
} key=0; // to initialize 'key' not as SPACE BAR
alan
Joined: 12 Nov 2012 Posts: 358 Location: South Africa
Posted: Fri Jun 02, 2017 2:26 am |
Try moving your printf to before the break command.
Every time the for loop completes it will print as there are no testing of a condition. |
art
Posted: Fri Jun 02, 2017 8:35 am |
Hi alan;
i've rearrange the code as you advised,but it still give the same result.
When i compile, it shows message that below line "Code has no effect"
How to solve this problem ?
Kindly please reply |
Posted: Fri Jun 02, 2017 8:59 am |
Read a C textbook....
In C, a 'statement', is a line of code, ending in a semi-colon, or a block of lines enclosed in {} brackets.
The IF statement executes the following statement.
You have a semi-colon after it (a statement...).
So what gets executed?. |
