gjs_rsdi
PIC18F46K22 MCLR internal PU resistor |
Posted: Thu May 04, 2017 4:23 am |
Hi
I am using usually 10K resistor on the MCLR and it works fine.
My question is someone using the internal weak PU resistor on the MCLR of the PIC18F46K22 ?
Best wishes
Joe |
Joined: 01 Jul 2010 Posts: 9163 Location: Greensville,Ontario
Posted: Thu May 04, 2017 5:43 am |
Not me.....didn't even know it did.
I've always used a real 10K pullup. Now I just read about it and it's disabled during a 'power on reset' whether that affects your PIC code / operation...hmmmmmmm.
Frankly I've got 10,000 10K resistors here,so cost isn't an object. It doesn't really take up any board space, so that doesn't matter.
and
if it ain't broke.... it don't need fixing !!
Interesting though..off to build an Ark...ANOTHER 2" of rain today...sigh..
Jay |
Posted: Thu May 04, 2017 7:17 am |
Quite a few later PIC's have this feature.
If there is no significant length of track attached to the pin, and the environment is 'low noise', then it functions adequately. If there is any length of track, or the electrical noise is significant, then an external pullup is recommended. |
gjs_rsdi
Posted: Fri May 05, 2017 1:08 am |
Thank you for the answers
The question is how to use it. I suppose Microchip had something in mind when adding the resistor.
MCLR pin not connected maybe?
Best wishes
Joe |
Posted: Fri May 05, 2017 11:04 am |
Exactly.
It's always there if the pin is setup as MCLR, so nothing involved in 'using it'. It ensures that when the pin is set as MCLR, it is never floating. |
gjs_rsdi
Posted: Fri May 05, 2017 5:17 pm |
Thanks again Ttelmah
Best wishes
Joe |
