USB Device not recognized
doguhanpala
PostPosted: Thu May 04, 2017 3:23 am     Reply with quote
Hello
I have a pcb board (the pic is 18f4550 tqfp) and i am doing some tests o it. I want to check usb connection on my board. I uploaded this code to my pic. I hear the usb connection sound on windows but it gives the warning, usb device not recognized. I want to learn, whether the problem is on hardware or on my code. Any ideas?
Thank you so much!
#if !defined(__PCH__)
 #error USB CDC Library requires PIC18
#endif
#include <18F4550.h>
#fuses  HSPLL,NOWDT, PUT, NOLVP,NOMCLR,NOPROTECT,NOLVP,NODEBUG,NOBROWNOUT,USBDIV,PLL5,CPUDIV1,VREGEN,ICSP2          //ICPRT enabled
#device ADC=10
#use delay(clock=48000000)
#include<usb.h>
#include<usb_cdc.h>
#include <pic18_usb.h>
#define rp_getc usb_cdc_getc
#define rp_putc usb_cdc_putc
  usb_cdc_init();
  usb_init();
  usb_task();
Best wishes
Doguhan
PostPosted: Thu May 04, 2017 3:59 am     Reply with quote
The code you have dies...
Drops off the end, so isn't running.
When Windows tries to enumerate the device, there is no code there to answer...
doguhanpala
PostPosted: Thu May 04, 2017 5:35 am     Reply with quote
sorry for the newbie mistake... i will add a while(true). thank you so much Ttelmah!
