PortB on change interrupts
rfjhh
PostPosted: Tue Apr 18, 2017 4:16 pm     Reply with quote
I'm writing a code for manage a keyboard using the portb on change interrupts.
The program runs well in simulation, but doesn't for real. I'm monitoring the INTCON register and in simulation the RBIF is turned off as it must to be after each CLEAR, but in the prototype, at the beginning is turned off, but after the first interrupt, it remains turned on.
I've read something in the datasheet:
"MCLR and WDT Reset do not affect the previous value data latch. The RBIF bit will be cleared upon Reset but will set again if the mismatch exists"
I don't understand what does it mean.
The program is as follow:
#include<16f887.h>
#device adc=10
#use delay (clock = 8 MHz)
#fuses INTRC, NOWDT, NOBROWNOUT, NOLVP, NOPROTECT, NOIESO, NOFCMEN, PUT
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#include<LCD.c>
#define use_portd_lcd TRUE
int16 t_data=0;
int8 conta_1min = 0, conta_125 = 0, cols = 0;
void lee_tec_mat()
   int8 i, j, dato;
   int8 fila[4]={1, 2, 4, 8};
   int8 columna[4]={1, 2, 4, 8};
   int16 num[4][4]={{ 1,  2,  3, 10},
                    { 4,  5,  6, 11},
                    { 7,  8,  9, 12},
                    {14,  0, 15, 13}};
   for(i=0;i<4;i++)
      output_b(fila[i]);
      for(j=0;j<4;j++)
         dato = (input_b()>>4)&0x0f;
         if(dato==columna[j])
            t_data=num[i][j];
            i=3; j=3;
    int8  conta = 0, err = 0;
    int32 clave = 0, num = 0;
    set_tris_a(0xf9);
    set_tris_b(0xf0);
    set_tris_c(0x00);
    setup_oscillator(OSC_8MHZ);
    setup_timer_1 ( T1_INTERNAL | T1_DIV_BY_8 );
/*Habilito interrupciones en PuertoB para entrada de teclado*/
    enable_interrupts(GLOBAL);       // INTCON<7:6>
    enable_interrupts(INT_RB4);      // INTCON<3>, IOCB<4>
    enable_interrupts(INT_RB5);      // INTCON<3>, IOCB<5>
    enable_interrupts(INT_RB6);      // INTCON<3>, IOCB<6>
    enable_interrupts(INT_RB7);      // INTCON<3>, IOCB<7>
    t_data = 16;
    for(;;)
       output_b(0x0f);
       output_c(*0x0b);
       if(cols != 0)
         lee_tec_mat();
          if(t_data == 11)               // borrar
             num = 0;
             conta = 0;
             lcd_putc("\f");
             if(t_data == 10)            // Aceptar
                if(input(PIN_A0))        // Selector
                   clave = num;
                   lcd_gotoxy(1,1);
                   printf(lcd_putc, " Clave aceptada ");
                   if(num == clave)      // Número correcto
                      lcd_gotoxy(1,1);
                      printf(lcd_putc, "     Acceso     ");
                      lcd_gotoxy(1,2);
                      printf(lcd_putc, "   concedido    ");
                      bit_set(*0x05, 1);
                      err = 0;
                   else               // Número erróneo
                      err++;
                      if(err == 3)
                         lcd_gotoxy(1,1);
                         printf(lcd_putc, " Clave  erronea ");
                         lcd_gotoxy(1,2);
                         printf(lcd_putc, "Espere un minuto");
                         conta_1min = 0;
                         while(conta_1min <= 6)
                            conta_125 = 0;
                            bit_set(*0x05, 2);
                            set_timer1(15524);
                            while(conta_125 <= 2)
                            conta_125 = 0;
                            bit_clear(*0x05, 2);
                            set_timer1(15524);
                            conta_1min++;
                         err = 0;
                         lcd_gotoxy(1,2);
                         printf(lcd_putc, "Error %1u", err);
                delay_ms(2000);
                num = 0;
                conta = 0;
                lcd_putc("\f");
                bit_clear(*0x05, 1);      // Borra RA1
             else                     // Número
                conta++;
                if(conta <= 5)            // Menos de 5 cifras
                   num = num*10 + t_data;
                   lcd_gotoxy(5,1);
                   printf(lcd_putc, "%5Lu", num);
                   t_data = 16;
          do
          {clear_interrupt(INT_RB);
          }while(((input_b()>>4)&0x0f)!=0);
          delay_ms(10);
          bit_set(*0x0b,3);         // habilito interrupción RB
          t_data = 16;
          cols = 0;
#int_timer1
void inter_t1()
   conta_125++;
   set_timer1(15524);
   clear_interrupt(INT_TIMER1);
#int_rb
void inter_tecla()
    int8 i, j = 0;
    //******* temporización por rebote de entrada
    for(i=0;i<250;i++)
       for(j=0;j<5;j++)
    cols = (input_b()>>4)&0x0f;
    output_b(input_b());
    bit_clear(*0x0b, 3);   // deshabilito INT_RB (INTCON<3> = 0)
PostPosted: Tue Apr 18, 2017 6:53 pm     Reply with quote
1. Is the keyboard a 3x4 keypad, similar to the link below?
https://www.digikey.com/product-detail/en/grayhill-inc/96AB2-102-F/GH5001-ND/180929
2. Do you have pull-up resistors (10K) on the Interrupt-on-change pins on PortB ?
3. In your program you have many lines of code like this:
bit_set(*0x05, 1);
Are you aware that you can do the same thing with CCS code ? Example:
output_high(PIN_A1);
If you do it the CCS way, the code is a lot easier to read.
4. What is your CCS compiler version ?
rfjhh
PostPosted: Wed Apr 19, 2017 11:19 am     Reply with quote
The keyboard is a 4x4keypad.
I have pulldown resistors in PORTB<7:4>.
I use bit_set(*0x0b, 3) because I try to enable or disable RBINT. I dont use it for a port.
I have the version 5
The note: "MCLR and WDT Reset do not affect the previous value data latch. The RBIF bit will be cleared upon Reset but will set again if the mismatch exists" what does it mean?
PostPosted: Wed Apr 19, 2017 12:12 pm     Reply with quote
You need to use fast_io.
Otherwise, this line:
Will set the whole port as output, and nothing will ever work again.....
It also doesn't make any sense as a line anyway....
rfjhh
PostPosted: Wed Apr 19, 2017 12:19 pm     Reply with quote
I'm already using fast_io:
#include<16f887.h>
#device adc=10
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#include<LCD.c>
set_tris_a(0xf9);
set_tris_b(0xf0);
set_tris_c(0x00);
