sergioigel
puts printf rs232 with PICF16F917 |
Posted: Mon Apr 10, 2017 7:28 am |
hi,
I try to use rs232 with the PIC16F917 but the program freezes when i use the routine PUTS or PRINTF.
Somebody help me ?
I try variations but nothing works.
#use delay(clock=20000000)//,RESTART_WDT)
#use rs232(baud=115200, xmit=pin_c6, rcv=pin_c7)
//#use rs232(baud=115200, BRGH1OK, xmit=pin_c6, rcv=pin_c7, PARITY=N, BITS=8)
//#use rs232(baud=115200, BRGH1OK, xmit=pin_c6, rcv=pin_c7, PARITY=N, BITS=8, TXISR)
//#use rs232(BAUD=115200, BRGH1OK, MAX_ERROR=9, UART1, XMIT=PIN_c6, RCV=PIN_c7, PARITY=N, BITS=8, STOP=1, TXISR, STREAM=uart1, ERRORS) |
Posted: Mon Apr 10, 2017 8:19 am |
Post a complete test program with the #include for the PIC, any #device
statements, #fuses, #use delay(), #use rs232(), main(), and some short
code that shows the problem. Example of a test program:
http://www.ccsinfo.com/forum/viewtopic.php?t=55769&start=9
Also post your compiler version. It's given at the top of the .LST file
after a successful compilation. It's a number such as 5.071 or 4.141, etc.
Also, tell us how you are doing the testing ? What external circuits do
you have connected to pins C6 and C7 ? What program or method are
you using to see the characters sent by printf() ? |
sergioigel
Posted: Mon Apr 10, 2017 9:50 am |
I use multiple files to divide the source. When i put the files together to post here, i try to compile and then it works now. I will see what is the problem in other locations in my project. |
