using #define on multiple pins
jameszum
PostPosted: Tue Sep 27, 2016 1:30 pm     Reply with quote
Good Morning
I am working on a project where I have a number of control lines going off to a number of modules. It would be nice if I were able to put the control lines in n array such as
#define port_select[8]  {PIN_F13,PIN_B14,PIN_H6,PIN_F2,PIN_A14,PIN_A4,PIN_H14,PIN_D13};
is this possible?
coding would be something like
for i=0; i<9; i++) output_high(port_select[i]) ;
Thank you
PostPosted: Tue Sep 27, 2016 2:32 pm     Reply with quote
I don't have the PCD compiler, but I made a test program for an 18F PIC.
#include <18F8722.h>
#fuses INTRC_IO,NOWDT,PUT,BROWNOUT,NOLVP
#use delay(clock=4M)
int16 port_select[8] = {PIN_F3,PIN_B4,PIN_H6,PIN_F2,PIN_A5,PIN_A4,PIN_H4,PIN_D3};
int8 i;
for(i=0; i<8; i++)
    output_high(port_select[i]);
while(TRUE);
Now look at the for() loop in the .LST file:
.................... for(i=0; i<8; i++)
0009A:  CLRF   14
0009C:  MOVF   14,W
0009E:  SUBLW  07
000A0:  BNC   00E2
....................     output_high(port_select[i]);
000A2:  BCF    FD8.0
000A4:  RLCF   14,W
000A6:  CLRF   03
000A8:  ADDLW  04
000AA:  MOVWF  FE9
000AC:  MOVLW  00
000AE:  ADDWFC 03,W
000B0:  MOVWF  FEA
000B2:  MOVFF  FEC,16
000B6:  MOVF   FED,F
000B8:  MOVFF  FEF,15
000BC:  MOVFF  15,17
000C0:  MOVLW  01
000C2:  MOVWF  18
000C4:  MOVLW  0F
000C6:  MOVWF  1A
000C8:  MOVLW  89
000CA:  MOVWF  19
000CC:  RCALL  0004
000CE:  MOVFF  15,17
000D2:  CLRF   18
000D4:  MOVLW  0F
000D6:  MOVWF  1A
000D8:  MOVLW  92
000DA:  MOVWF  19
000DC:  RCALL  0004
000DE:  INCF   14,F
000E0:  BRA    009C
That's not all of it. Here's the routine at address 0x00004 that it calls:
00004:  MOVF   17,W
00006:  ANDLW  07
00008:  MOVWF  00
0000A:  RRCF   17,W
0000C:  MOVWF  01
0000E:  RRCF   01,F
00010:  RRCF   01,F
00012:  MOVLW  1F
00014:  ANDWF  01,F
00016:  MOVF   01,W
00018:  ADDWF  19,W
0001A:  MOVWF  FE9
0001C:  MOVLW  00
0001E:  ADDWFC 1A,W
00020:  MOVWF  FEA
00022:  CLRF   01
00024:  INCF   01,F
00026:  INCF   00,F
00028:  BRA    002C
0002A:  RLCF   01,F
0002C:  DECFSZ 00,F
0002E:  BRA    002A
00030:  MOVF   18,F
00032:  BZ    003A
00034:  MOVF   01,W
00036:  IORWF  FEF,F
00038:  BRA    0040
0003A:  COMF   01,F
0003C:  MOVF   01,W
0003E:  ANDWF  FEF,F
00040:  RETURN 0
So indirect addressing of i/o pins is incredibly inefficient and time-consuming.
PostPosted: Tue Sep 27, 2016 2:35 pm     Reply with quote
No.
Just use a constant array.
const unsigned int16 port_select[8]
= {PIN_F13,PIN_B14,PIN_H6,PIN_F2,PIN_A14,PIN_A4,PIN_H14,PIN_D13};
#defines are not code or variables. They are 'text substitution macros' all done at compile time/ you can substitute in 'values', but not pick parts of them like this.
However the pin 'names', themselves are just #defines, and are really just numbers.
Also 'beware'. A 'output_high' using a variable, is a lot larger/slower than the output_high on a constant value. You'll probably find it is smaller and quicker to just have the 8 values hard coded.....
After posting, I see PCM_Programmer also pointed this out, while I was typing. Smile
jameszum
PostPosted: Tue Sep 27, 2016 2:40 pm     Reply with quote
Thank you
jameszum
PostPosted: Tue Sep 27, 2016 2:43 pm     Reply with quote
Thank You
