CCS Program Load ERROR
hayee
PostPosted: Thu Aug 04, 2016 3:51 am     Reply with quote
Hi
I am using PIC24HJ128GP306A microcontroller.
CCS Compiler version 4.124 and ICD-U64 for Programming.
When i program PIC24HJ128GP306A, i getting an error "DOWNLOAD ERROR".When i see the details it shows
It shows that the ICD is trying to program the PIC24HJ128GP306 instead of PIC24HJ128GP306A
and the voltage on MCLR pins goes to "0" after that error.
I am using ICSP2 port (PGEC2 & PGED2) and my hardware is according to those pins.
My code is:
#include <24HJ128GP306A.h>
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NOWDT
#FUSES PR
#FUSES ICSP2                    //ICD uses PGC2/PGD2 pins
#use delay(clock=29491200) // crystal value is 29.4912Mhz
   setup_spi( FALSE );
   setup_spi2( FALSE );
   setup_timer1(TMR_DISABLED|TMR_DIV_BY_1);
   // TODO: USER CODE!!
Am i doing something wrong?
PostPosted: Thu Aug 04, 2016 6:11 am     Reply with quote
Contact CCS. It's been my experience that they'll fix issues like this VERY quickly.
