argo
Question |
Posted: Wed May 11, 2016 1:51 pm |
Hi all
I would like to know if this code uses (is based) "timer interrupts"?
Thank you in advance!
#include<12f683.h>
#fuses INTRC_IO,NOWDT,PUT,NOPROTECT,NOMCLR,NOBROWNOUT
#use delay(CLOCK=8000000) //8MHz
#byte GP=5
#bit IRSIG=GP.3
#define ON 1
#define OFF 0
#define HI 1
#define LOW 0
#define el_on 0x31
#define el_off 0x0e
#define rd_on 0x02
#define rd_off 0x35
signed long th_count,rd_count,el_count;
signed long rev_mix,rd_duty,al_count,rd_trim;
int cycl_count,el_duty;
byte gp_now;
// PWM
#int_rtcc
void soft_pwm()
set_timer0(156);
if(cycl_count < rd_duty){ // ON
gp_now=gp_now | rd_on;
GP=gp_now;
else{ // OFF
gp_now=gp_now & rd_off;
GP=gp_now;
if(cycl_count < el_duty){ // ON
gp_now=gp_now | el_on;
GP=gp_now;
else{ // OFF
gp_now=gp_now & el_off;
GP=gp_now;
cycl_count++;
cycl_count %=99;
main(){
int gcount;
setup_oscillator(OSC_8MHz);
setup_comparator(NC_NC);
setup_ccp1(CCP_PWM);
setup_adc_ports(NO_ANALOGS);
setup_timer_0(RTCC_INTERNAL | RTCC_DIV_4);
set_timer0(246);
//0.5us*4*(255-246+1)=0.00002s(=0.02ms)
setup_timer_2(T2_DIV_BY_4,255,1);
enable_interrupts(INT_RTCC); // Timer0
set_tris_a(0x08); // GP3
/* GP 5 4 3 2 1 0
el3 el2 SG MTR MTT el1
0 0 1 0 0 0
cycl_count=rd_duty=el_duty=0;
th_count=0;
rd_trim=0;
gp_now=OFF;
while(1){
gcount=0;
while(gcount < 30){
if(IRSIG==HI){
delay_us(100);
gcount++;
else{
gcount=0;
While(IRSIG==HI){
//**************** Timer0 ******************
disable_interrupts(INT_RTCC);
// 1ch
al_count=0;
while(IRSIG==LOW){ // Low
delay_us(6);
al_count=al_count+1;
while(IRSIG==HI){
delay_us(6);
// 2ch
el_count=0;
while(IRSIG==LOW){
delay_us(6);
el_count=el_count+1;
while(IRSIG==HI){
delay_us(6);
// 3ch
th_count=0;
while(IRSIG==LOW){
delay_us(6);
th_count=th_count+1;
while(IRSIG==HI){
delay_us(6);
// 4ch
rd_count=0;
while(IRSIG==LOW){
delay_us(6);
rd_count=rd_count+1;
while(IRSIG==HI){
delay_us(6);
//************** Timer0 ******************
if(al_count > 180){
rd_trim=rd_trim+2;
if(al_count < 130){
rd_trim=rd_trim-2;
if(el_count<105){
el_count=100;
if(el_count>180){
el_count=205;
if(el_count > 160){
el_duty=(el_count-155)*2;
else{
el_duty=0;
rev_mix=th_count;
if(th_count<110){
th_count=0;
else if(th_count>190){
th_count=1023;
else{
th_count=(th_count-100)*10; }
set_pwm1_duty(th_count);
rev_mix=rev_mix-100;
if(rd_count<110){
rd_count=100;
if(rd_count>200){
rd_count=200;
if(150 <= rd_count && rd_count <=160){
rd_count=155;
if(rev_mix < 45){
rd_duty=rev_mix+(rd_count-155)+rd_trim;
else{
rd_duty=rev_mix/10*7+14+(rd_count-155)+rd_trim;
Posted: Wed May 11, 2016 1:53 pm |
Yes.
#int_rtcc
This defines the timer0 (rtcc) interrupt handler. |
argo
Posted: Wed May 11, 2016 2:35 pm |
Thanks for the reply, Ttelmah. |
