Joined: 01 Jul 2010 Posts: 9615 Location: Greensville,Ontario
Posted: Sat Apr 30, 2016 5:03 am |
When asking a question about a 'driver', you should post a link to the actual device you are using, either the mfr datasheet if you are making the PCB or the 'module' that you've bought for the device.
Also post compiler version and PIC you've chosen as that will affect the driver as well.
edit. Had a quick look at the datasheet, seems to be an I2C device AND is 3 volts, so choose a PIC that is rated for 3 volts ( xxxLFyyyyy) to make it easy to interface with. Also the 'driver' will of course depend upon your analog sensor.... I'd suggest buyng a complete 'developement' kit unless you're skilled at SMD PCB mfg !
Jay |
