isaac aiyanyo Guest
| 1D to 2D array |
Posted: Sun Dec 15, 2002 2:14 pm |
Hello pic c gurus
i would be pleased if someone can help me out this
problem.
i am trying to convert the 1D array pat[32] to a
2D array then send this to port b.
this works perfectly as a 1D array so i need to change
CHAR const pat[32] to a 2D array and also
where port_b = pat[index] to port_b=pat[down][across];
but the display don't work at all i have being trying
to see where i am going wrong for a few nights with no joy
so guys i do really need your help here.
Thanks in advance
Isaac
(oo)
/(____)\
#include <16F876.H>
#fuses HS,NOWDT,NOPUT,NOPROTECT,NOBROWNOUT,NOLVP
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,RESTART_WDT,ERRORS)
#IFNDEF EXP_OUT_ENABLE
#define Row 4
#define Col 8
#define EXP_OUT_ENABLE PIN_C2
#define EXP_OUT_CLOCK PIN_C1
#define EXP_OUT_DO PIN_C0
#define NUMBER_OF_74595 4
#ENDIF
#include <74595.C>
#byte port_a=5
#byte port_b=6
#byte port_c=7
char const pat[Row][Col]={
//CHAR const pat[32] = {
0,0xfc,0xfe,0x33,0x33,0xfe,0xfe,0, /* Fort A*/
0,0xff,0xff,0xdb,0xdb,0xff,0x66,0, /* Font B*/
0,0x7e,0xff,0xc3,0xc3,0xc3,0xc3,0, /* Font C*/
0,0xff,0xff,0xc3,0xc3,0xff,0x7e,0, /* Font D*/
main() // array holds the character maps for ABCD which scrolls//
int mask[4];
int data[4]; // array to store our data since i am
int delaycount;
int startposition;
int index;
int i,nelly;
int down,across;
set_tris_c(0);
set_tris_b(0);
port_c = 0;
port_b = 0;
startposition = 0;
delaycount = 3; // adjust this value to control scrolls speed
while (delaycount)
index = startposition;
mask[0]=0x01; // Initialize our mask
mask[1]=0x00;
mask[2]=0x00;
mask[3]=0x00;
for (i=0; i<32; i++) // we have 32 columns to drive
// store our mask in an array. we need to do this because
// the call to write_expanded_outputs will destroy the value
// passed in.
data[0] = mask[0]; // store which column we are driving
data[1] = mask[1]; // in an array
data[2] = mask[2];
data[3] = mask[3];
index = i + startposition; // point to the next pattern to display
if (index >= sizeof(pat)) // make sure that we don't exceed the array
index -= sizeof(pat);
port_b = 0; // disable driving the LEDs
write_expanded_outputs(data); // enable our column driver
// port_b = pat[index]; // drive our LEDs
nelly=i\%8;
for(down=0;down<Row;down++)
for (across =0;across
printf("\%x",pat[down][across]);
//printf("\%x",pat[index],"\r\n");
if (shift_left(mask,4,0))
mask[0] = 0x01;
// shift to the next column for next time
delay_us(700); // adjust this value to control the drive time
//for the leds
--delaycount; // decrement our delay loop counter
++startposition; // Point to the next data pattern
if (startposition >= sizeof(pat)) // make sure that we don't exceed the array
startposition = 0;
___________________________
Original Post ID: 10055 |
isaac aiyanyo Guest
| Re: 1D to 2D array (sorted) |
Posted: Sun Dec 15, 2002 3:59 pm |
I have managed to get the display to work now
but i still now help in making it scroll
the scroll don't work anymore so if you have any
suggestions it would be highly welcomed
:= Thanks in advance
:= Isaac
:= (oo)
:= /(____)\
:=#include <16F876.H>
:=#fuses HS,NOWDT,NOPUT,NOPROTECT,NOBROWNOUT,NOLVP
:=#use delay(clock=20000000)
:=#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,RESTART_WDT,ERRORS)
:=#IFNDEF EXP_OUT_ENABLE
:=#define Row 4
:=#define Col 8
:=#define EXP_OUT_ENABLE PIN_C2
:=#define EXP_OUT_CLOCK PIN_C1
:=#define EXP_OUT_DO PIN_C0
:=#define NUMBER_OF_74595 4
:=#ENDIF
:=#include <74595.C>
:=#byte port_a=5
:=#byte port_b=6
:=#byte port_c=7
:=char const pat[Row][Col]={
:=//CHAR const pat[32] = {
:= 0,0xfc,0xfe,0x33,0x33,0xfe,0xfe,0, /* Fort A*/
:= 0,0xff,0xff,0xdb,0xdb,0xff,0x66,0, /* Font B*/
:= 0,0x7e,0xff,0xc3,0xc3,0xc3,0xc3,0, /* Font C*/
:= 0,0xff,0xff,0xc3,0xc3,0xff,0x7e,0, /* Font D*/
:=main() // array holds the character maps for ABCD which scrolls//
:=int mask[4];
:=int data[4]; // array to store our data since i am
:=int delaycount;
:=int startposition;
:=int index;
:=int i,nelly;
:=int down,across;
:=set_tris_c(0);
:=set_tris_b(0);
:=port_c = 0;
:=port_b = 0;
:=startposition = 0;
:=while(1)
:= delaycount = 3; // adjust this value to control scrolls speed
:= while (delaycount)
:= index = startposition;
:= mask[0]=0x01; // Initialize our mask
:= mask[1]=0x00;
:= mask[2]=0x00;
:= mask[3]=0x00;
:= for (i=0; i<32; i++) // we have 32 columns to drive
:= // store our mask in an array. we need to do this because
:= // the call to write_expanded_outputs will destroy the value
:= // passed in.
:= data[0] = mask[0]; // store which column we are driving
:= data[1] = mask[1]; // in an array
:= data[2] = mask[2];
:= data[3] = mask[3];
:= index = i + startposition; // point to the next pattern to display
:= if (index >= sizeof(pat)) // make sure that we don't exceed the array
:= index -= sizeof(pat);
:= port_b = 0; // disable driving the LEDs
:= write_expanded_outputs(data); // enable our column driver
:= // port_b = pat[index]; // drive our LEDs
:= nelly=i\%8;
:= for(down=0;down<Row;down++)
:= for (across =0;across
:= port_b=pat[down][across];
:= printf("\%x",pat[down][across]);
:= //printf("\%x",pat[index],"\r\n");
:= if (shift_left(mask,4,0))
:= mask[0] = 0x01;
:= // shift to the next column for next time
:= delay_us(700); // adjust this value to control the drive time
:= //for the leds
:= --delaycount; // decrement our delay loop counter
:= ++startposition; // Point to the next data pattern
:= if (startposition >= sizeof(pat)) // make sure that we don't exceed the array
:= startposition = 0;
Original Post ID: 10056 |
isaac aiyanyo Guest
| Re: 1D to 2D array |
Posted: Sun Dec 15, 2002 4:03 pm |
i forgot to include the code
here it is.
Thanks in advance
Isaac
(oo)
/(____)\
#include <16F876.H>
#ENDIF
#include <74595.C>
#byte port_a=5
#byte port_b=6
#byte port_c=7
char const pat[4][8]={
//CHAR const pat[40] = {
int mask[4];
int delaycount;
int startposition;
int index;
int i,x,nelly;
signed int down;
signed int across=8;
set_tris_c(0);
set_tris_b(0);
port_c = 0;
port_b = 0;
startposition = 0;
delaycount = 2; // adjust this value to control scrolls speed
while (delaycount)
mask[1]=0x00;
mask[2]=0x00;
mask[3]=0x00;
down=-1;
// passed in.
data[2] = mask[2];
data[3] = mask[3];
across=i\%8;
if (!across) down++; //this should be ok
//BEWARE nothing stops 'down'
port_b = pat[down][across]; //incrementing beyond the array size
//so down is given a value of
// -1 outside the loop
// there might be another way!
mask[0] = 0x01;
//for the leds
startposition = 0;
:=#define Row 4
:=#define Col 8
:=#ENDIF
:=#byte port_a=5
:=#byte port_b=6
:=#byte port_c=7
:=int mask[4];
:=int delaycount;
:=int index;
:=int i,nelly;
:=int down,across;
:=set_tris_c(0);
:=set_tris_b(0);
:=port_c = 0;
:=port_b = 0;
:=while(1)
:= mask[1]=0x00;
:= mask[2]=0x00;
:= mask[3]=0x00;
:= // passed in.
:= nelly=i\%8;
:= mask[0] = 0x01;
:= //for the leds
Original Post ID: 10057 |
