MarkchchPIC
Joined: 14 Jan 2015 Posts: 18 Location: Christchurch New Zealand
SSD1306 Driver |
Posted: Sun Nov 01, 2015 2:15 pm |
Hi All,
Just a question about the new SSD1306 Driver.
Can someone confirm if it will operate on version 4.71 please.
I am having no success compiling it at the moment and suspect it may use features only offered in version 5
Cheers
Mark |
MarkchchPIC
Posted: Sun Nov 01, 2015 4:11 pm |
Apologies
Version 4.071 |
Posted: Mon Nov 02, 2015 3:33 am |
4.071, is close to when V4, first actually started working. I'd say anything after perhaps 4.100, would work OK, but 4.071, was at a point where quite a few functions did not work as they should. The break point was around 4.100(ish), where quite a few things actually started working.
Have just tried and the code compiles OK, and works with 4.141, and compiles with 4.104, but not with 4.099.
It's the initialisation of the arrays with #defines that fails. You would have to hard code these to using numbers. Also I suspect you'd have to hard code the references to the ROM arrays, rather than using pointers. |
