Entering ADC while loop
art
PostPosted: Mon Sep 28, 2015 5:18 pm     Reply with quote
Hi, i'm using 'ENTER' key on keyboard to exit ADC while loop for the first time. It can exit the loop and and display "Enter 'Z' for ADC or 'z' for RELAY :". But the main problem here is when I enter 'Z' once again, it cannot enter the ADC loop and keep repeating "Enter 'Z' for ADC or 'z' for RELAY :".
What is wrong with my code.
#include <18F4550.h>
#DEVICE ADC=10
#fuses HS,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#include <string.h>
#include <input.c>
#include <stdio.h>
#include <stdlib.h>
main()
      char ch;
      unsigned char key;
      float  value, min;
      int8 binary_string[10];
         while(true)
              printf("\n\n");
              printf("Enter 'Z' for ADC or 'z' for RELAY : \n");
              ch=getc();
              if(ch=='Z')
                     while (key!=13)
                        setup_port_a( ALL_ANALOG );
                        setup_adc( ADC_CLOCK_INTERNAL );
                        set_adc_channel( 0 );
                             if(kbhit())
                              {key=getch();}
                                value = Read_ADC();
                                min=value*5/1023 ;
                                printf("\r%2.3f",min);
              if(ch=='z')
                     while (1)
                             printf("Enter Relay Number : \n");
                             get_string(binary_string,9);
                             output_B((int8)strtoul(binary_string,0,2));
RLScott
Re: Entering ADC while loop
PostPosted: Wed Sep 30, 2015 3:42 pm     Reply with quote
The problem is you do not initialize the "key" variable before checking it at the top of the ADC loop. Once it gets set to 13 it stays set to 13 forever. It can never get changed. Add key=0 just after the 'Z' is recognized.
Robert Scott
Real-Time Specialties
Embedded Systems Consulting
art
PostPosted: Thu Oct 01, 2015 8:27 pm     Reply with quote
Dear RLScott,
It works. Thank you very much...
