RTOS and Interrupt Timer, CCP2
lambk89
PostPosted: Thu Sep 17, 2015 8:04 am     Reply with quote
Hi!
Can you help me?
I use RTOS and Interrupt Timer 1. When I turn off Timer 1 then ccp2 happen but when i turn on Timer 2 then Interrupt ccp2 can't do.
This is my code:
#include "E:\reading\Lab\Distant sensor\example\CCP\RTOS.h"
#define TRIGGER PIN_A3
int16 fall, rise;
int echo = 0;
#use rtos(timer = 0, minor_cycle = 10ms)
#task (rate = 1000ms, max = 10ms)
void Init_Sensor();
#task (rate = 100ms, max = 10ms)
void display();
void trig()
   output_high(TRIGGER);
   delay_us(10);
   output_low(TRIGGER);
double dis()
   return (double)(fall - rise)*0.8/56;
void display()
   printf("Khoang cach = %f \n",dis() );
void Init_Sensor()
   echo = 0;
   setup_ccp2(CCP_CAPTURE_RE);
   trig();
   //printf("Init \n");
#int_CCP2
void  CCP2_isr(void)
   if(echo == 0)
      rise = CCP_2;
      setup_ccp2(CCP_CAPTURE_FE);
      echo = 1;
      printf("echo = 0 \n");
      fall = CCP_2;
      printf("echo = 1 \n");
   setup_adc(ADC_CLOCK_DIV_2|ADC_TAD_MUL_0);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
   setup_vref(FALSE);
   enable_interrupts(INT_CCP2);
//Setup_Oscillator parameter not selected from Intr Oscillator Config tab
   // TODO: USER CODE!!
   rtos_run();
PostPosted: Fri Sep 18, 2015 9:46 pm     Reply with quote
I don't see any place in your code where you turn on Timer2.
PostPosted: Sat Sep 19, 2015 12:28 am     Reply with quote
There is also the old classic 'wrong line':
This _enables_ the SPI, with the slave select disabled.
The command to disable the SPI, is:
setup_spi(FALSE);
Can affect how other parts work....
lambk89
PostPosted: Sun Sep 20, 2015 7:55 am     Reply with quote
Sorry! That's timer 1 not timer 2.
lambk89
PostPosted: Sun Sep 20, 2015 7:57 am     Reply with quote
setup_spi(FALSE);
I setup_spi like you but CCP2 not work.
lambk89
PostPosted: Sun Sep 20, 2015 7:58 am     Reply with quote
Sorry! I write wrong. That's timer 1
PostPosted: Sun Sep 20, 2015 10:07 am     Reply with quote
The reason is because you don't have an interrupt routine for Timer1.
You have enabled INT_TIMER1 interrupts, but without an #int_timer1
routine, the Timer1 interrupt flag bit will never be cleared. So, you will
get continuous Timer1 interrupts and your program will appear to be
locked up. Your program will spend all of its time executing the CCS
global interrupt handler code.
At a minimum, you need to add the following code to your program:
#int_timer1
void timer1_isr(void)
lambk89
PostPosted: Mon Sep 21, 2015 11:26 am     Reply with quote
#int_timer1
Thanks!
