Another RF link over UART (one-way)
PICoHolic
PostPosted: Tue Jun 30, 2015 7:25 am     Reply with quote
Inspired by: http://www.ccsinfo.com/forum/viewtopic.php?t=22525
(Optimized and Rx timeout added [optional])
File: manchester.h
#ifndef  _MANCHESTER_H
#define  _MANCHESTER_H
#define  MAN_PREAMB  0x55  //preamble
#define  MAN_SOP     0xFF  //Start of payload
File manchester.c
#include "manchester.h"
char manchester[16]={
   0b01010101, //0
   0b01010110, //1
   0b01011001, //2
   0b01011010, //3
   0b01100101, //4
   0b01100110, //5
   0b01101001, //6
   0b01101010, //7
   0b10010101, //8
   0b10010110, //9
   0b10011001, //A 10
   0b10011010, //B 11
   0b10100101, //C 12
   0b10100110, //D 13
   0b10101001, //E 14
   0b10101010}; //F 15
void TxManchester(int8 Dt)
   putc(manchester[Dt>>4], PORT1);        //MSB
   putc(manchester[Dt & 0x0F], PORT1);    //LSB
signed int8 _RxManchester(int8 Dt)
   int8 i=0;
   while ((Dt!=manchester[i]) && (i<16))
      i++;
   return i<16?i:-1;
int1 ManchesterToBinary(int8 msb, int8 lsb, int8 *bin)
   signed int8 ret1, ret2;
   ret1 = _RxManchester(msb);
   if (ret1 != -1)
      ret2 = _RxManchester(lsb);
      if (ret2 != -1)
         *bin = (ret1 << 4) | ret2;
         return 1;
         return 0;
      return 0;
File: Tx.c
#include "manchester.c"
void TxData(int8 *DtBuff)  //data is being sent inverted
   int8 i;
   int8 len = DtBuff[0];   //1st byte is length
   putc(MAN_PREAMB, PORT1);
   putc(MAN_SOP, PORT1);
   for (i=0; i<len; i++)         //send payload
      TxManchester(DtBuff[i]);   //last byte in DtBuff should be checksum
File Rx.h
#ifndef  RX_H
#define  RX_H
#define  MAXRXDATA      16
#define  MAXRXDATAMSK   MAXRXDATA-1
File: Rx.c
#include "Rx.h"
int8 RxDataBuff[MAXRXDATA];
int8 RxPrt = 0;
int1 RxDtReady = 0;
int16 MaxBytesTimeout;
#define  RxByteTimeout        525   //in cycles = 8.4ms = time for 1 byte to get Rx @ 1200
#define  SetUARTTimeOut(n)    {MaxBytesTimeout=(RxByteTimeout*n); set_timer0(0xFFFF - MaxBytesTimeout); clear_interrupt(INT_TIMER0); enable_interrupts(INT_TIMER0);}
#define  ResetUARTTimeOut()   disable_interrupts(INT_TIMER0)
#INT_TIMER0
void TIMER0_isr(void)
   //Reset all:
   RxDtReady = FALSE;
   RxPrt = 0;
   ResetUARTTimeOut();
#INT_RDA2
void RDA2_isr(void)
   int8 d;
   static int8 RxDtPayPrt = 0;
   static int8 ExpectedLen;
   static int1 msb = 1;
   static int8 msb_data;
   d = getc(PORT2);
   switch (RxPrt)
   case 0:
   case 1:
      if (d==MAN_PREAMB)
         RxPrt++;
         RxPrt = 0;     //reset
   case 2:
      if (d==MAN_SOP)
         RxPrt++;
         RxPrt = 0;     //reset
   case 3:
         if (!msb)
            if (ManchesterToBinary(msb_data, d, &ExpectedLen)) //get binary value
                  RxDataBuff[0] = ExpectedLen;
                  SetUARTTimeOut((ExpectedLen-1) * 2);
                  RxDtPayPrt = 1;   //move 2nd position
                  RxPrt++;
               RxPrt = 0;     //reset
            msb_data = d;
         msb = !msb;
   default:
         if (!msb)
            if (ManchesterToBinary(msb_data, d, &d))  //get binary value
               RxDataBuff[RxDtPayPrt++ & MAXRXDATAMSK] = d; //copy & move to next position
               if (RxDtPayPrt == ExpectedLen)
                  RxPrt = 0;     //reset
                  RxDtReady = 1; //flag
               RxPrt = 0;     //reset
            msb_data = d;
         msb = !msb;
Transmit test code:
#include "Tx.c"
Data[0] = 5;
Data[1] = 0;
Data[2] = 1;
Data[3] = 2;
Data[4] = Data[0] ^ Data[1] ^ Data[2] ^ Data[3];
TxData(Data);
Receive test code (RDAx interrupt must be enabled)
#include "Rx.c"
setup_timer_0(T0_INTERNAL | T0_DIV_32);   //for Rx timeout (525 per Rx byte) XT = 8Mhz
if (RxDtReady)
   RxDtReady = 0;
   if ((RxDataBuff[0] == 5) && (RxDataBuff[4] == (RxDataBuff[0] ^ RxDataBuff[1] ^ RxDataBuff[2] ^ RxDataBuff[3])))
      // TO DO:...
Important notes:
1- Baud rate should be selected carefully (should be less than the maximum bit rate supported by the RF transmitter/receiver)
2- Both UART Tx & Rx must be inverted by hardware (1 way is to use transistors or a simple inverter)
Cheers!
