irmanao
zero crossing detection code question |
Posted: Tue Jun 30, 2015 5:23 am |
I would like to do zero crossing detection on a 50Hz signal (0.1V-3.1V) to fire triacs.
Would this code work?
Code: | #include <33EP512MU810.h>
#byte PORTD=0xF81
#byte PORTB =0xF83
void init_all (void);
float32 adc;
int VCC=5;
init_all();
WHILE (TRUE){
adc=(((float)read_adc()*VCC)/1023);
if (adc<1.63 && adc>1.57){
delay_ms(1);
output_high(PIN_D1);
delay_us(60);
output_low(PIN_D1);
void init_all(void){
set_tris_b(0xff);
set_tris_d(0x00);
setup_adc_ports( sAN0 | VSS_VDD );
setup_adc ( ADC_CLOCK_INTERNAL );
set_adc_channel ( 0 );
thanks |
Joined: 01 Jul 2010 Posts: 9453 Location: Greensville,Ontario
Posted: Tue Jun 30, 2015 7:04 am |
no.
some possible reasons
1) use of ADC_CLOCK_INTERNAL. Bad choice, read the adc section for more details.
2) use of float for ADC math result. HUGE delay in processing time. FP math should( must ?) be avoided especialyy in time critical events.
3) clock=4MHz. !! Way too slow
4) hardware. Normally you use a 'zero crossing opto coupler' to detect the zero cross.I think a MOC3011 is the part you should use.
5) zero cross should be an ISR, allowing PIC to do other stuff.
6) use of delay_ms() can easily miss the next zero cross.
That's just a quick answer....
asmboy
Posted: Tue Jun 30, 2015 8:59 am |
Your code is kind of a mess as is, but more important-
post your circuit schematic.
No way too know what you might be able to do without knowing
what you are connecting your code TO. |
irmanao
Posted: Tue Jun 30, 2015 9:10 am |
I'm using a dspic33e usb starter kit
thanks for the replies |
irmanao
Posted: Tue Jun 30, 2015 10:24 am |
1. Isn't this enough for 50Hz? (ADC Internal RC Oscillator Period 250 ns)
3. How do i determine the correct one?
4. My goal is to use only software.
6. Period is 20ms, so the next zero cross could be missed because of clock=4000000?
Thank you for your time,
(i am new to programming)
Posted: Tue Jun 30, 2015 12:50 pm |
First look at this thread:
<http://www.ccsinfo.com/forum/viewtopic.php?t=54087>
Then look at this one
<http://www.ccsinfo.com/forum/viewtopic.php?t=54077>
Within the last week, two important things already raised by Temtronic answered....
Realistically, to actually get a repeatable value using the ADC will be very hard. AC waveforms are not nice smooth sine waves. You will see spikes that will cross zero, that are nothing to do with the actual zero point of the waveform. To do this properly you would have to start working out where you are on the waveform, and work out when the smoothed curve crosses zero. A lot of quite complex maths. On any genuine AC waveform, a simple 'look for a particular value with the ADC', has no hope of working.....
This is why proper zero crossing detectors work by normally phase locking a synthetic waveform onto the incoming signal, and then using this to find the crossing point. Chips like the MOC3011 already mentioned will do a far better job, and far easier.
It is trying to use a screwdriver to drive a nail. Not the right tool for the job. It is possible to do, but only with much more complex code. |
