tmp102
Linuxbuilders
tmp102
PostPosted: Sat May 16, 2015 3:23 am     Reply with quote
Just in case if anybody is having problems with a code for tmp102 and negative values here I put mine:
long tmptt;
float tmptf;
int tmp01;
int tmp02;
short neg;
         //read temperature 12 bit value
         i2c_start();
         i2c_write(0x90);
         i2c_write(0x00);
         i2c_start();
         i2c_write(0x91);
         tmp01 = i2c_read();
         tmp02 = i2c_read();
         i2c_Stop();
         tmptt = make16(tmp01,tmp02);
         tmptt = tmptt >> 4;
         if (tmptt > 0x7FF)
            tmptt = ~tmptt+1;
            neg = 0; //negative value
            neg = 1; //positive value
         tmptt =  tmptt * 0.0625;
         tmptf = tmptt;
Help "d" others and then you shell receive some help from "d" others.
PostPosted: Sat May 16, 2015 11:05 am     Reply with quote
i2c_start();
i2c_write(0x90);
i2c_write(0x00);
i2c_start();
i2c_write(0x91);
tmp01 = i2c_read();
tmp02 = i2c_read();
i2c_Stop();
You are missing the NACK on the last read, and that is part of the TMP102
specification. See page 12 in the TMP102 data sheet, and look at this
diagram: Figure 9. Two-Wire Timing Diagram for Read Word Format
http://www.ti.com/lit/ds/symlink/tmp102.pdf
The data sheet is poorly written in this area. It shows an ACK by the
master (the PIC) on the last read. But then down in notes 2 and 3,
it says the master (the PIC) should leave SDA high to terminate a one
or two-byte read operation. This is a NACK !
The Philips i2c specification says on page 10, in section 3.16:
When SDA remains HIGH during this ninth clock pulse, this is defined as
the Not Acknowledge signal.
http://www.nxp.com/documents/user_manual/UM10204.pdf
So you should do a NACK on the last i2c_read(). This is done by giving
the function a parameter of 0.
