sshahryiar
Joined: 05 May 2010 Posts: 94 Location: Dhaka, Bangladesh
| SSD1306 4 Wire SPI OLED Library |
Posted: Tue Apr 28, 2015 9:53 am |
SSD1306.h
| Code: | #define D0 pin_B0
#define D1 pin_B1
#define RST pin_B2
#define DC pin_B3
#define SCL D0
#define SDA D1
#define DAT TRUE
#define CMD FALSE
#define Set_Lower_Column_Start_Address_CMD 0x00
#define Set_Higher_Column_Start_Address_CMD 0x10
#define Set_Memory_Addressing_Mode_CMD 0x20
#define Set_Column_Address_CMD 0x21
#define Set_Page_Address_CMD 0x22
#define Set_Display_Start_Line_CMD 0x40
#define Set_Contrast_Control_CMD 0x81
#define Set_Charge_Pump_CMD 0x8D
#define Set_Segment_Remap_CMD 0xA0
#define Set_Entire_Display_ON_CMD 0xA4
#define Set_Normal_or_Inverse_Display_CMD 0xA6
#define Set_Multiplex_Ratio_CMD 0xA8
#define Set_Display_ON_or_OFF_CMD 0xAE
#define Set_Page_Start_Address_CMD 0xB0
#define Set_COM_Output_Scan_Direction_CMD 0xC0
#define Set_Display_Offset_CMD 0xD3
#define Set_Display_Clock_CMD 0xD5
#define Set_Pre_charge_Period_CMD 0xD9
#define Set_Common_HW_Config_CMD 0xDA
#define Set_VCOMH_Level_CMD 0xDB
#define Set_NOP_CMD 0xE3
#define Horizontal_Addressing_Mode 0x00
#define Vertical_Addressing_Mode 0x01
#define Page_Addressing_Mode 0x02
#define Disable_Charge_Pump 0x00
#define Enable_Charge_Pump 0x04
#define Column_Address_0_Mapped_to_SEG0 0x00
#define Column_Address_0_Mapped_to_SEG127 0x01
#define Normal_Display 0x00
#define Entire_Display_ON 0x01
#define Non_Inverted_Display 0x00
#define Inverted_Display 0x01
#define Display_OFF 0x00
#define Display_ON 0x01
#define Scan_from_COM0_to_63 0x00
#define Scan_from_COM63_to_0 0x08
#use FAST_IO(B)
void OLED_init();
void OLED_write(unsigned char value, short type);
void OLED_gotoxy(unsigned char x_pos, unsigned char y_pos);
void OLED_fill(unsigned char bmp_data);
void OLED_clear_screen();
void OLED_set_start_column(unsigned char n);
void OLED_set_addressing_mode(unsigned char n);
void OLED_set_column_address(unsigned char r, unsigned char t);
void OLED_set_page_address(unsigned char r, unsigned char t);
void OLED_set_start_line(unsigned char n);
void OLED_set_contrast(unsigned char n);
void OLED_set_charge_pump(unsigned char n);
void OLED_set_segment_remap(unsigned char n);
void OLED_set_entire_display_on(unsigned char n);
void OLED_set_normal_or_inverse_display(unsigned char n);
void OLED_set_multiplex_ratio(unsigned char n);
void OLED_set_display_on_off(unsigned char n);
void OLED_set_start_page(unsigned char n);
void OLED_set_common_output_scan_direction(unsigned char n);
void OLED_set_display_offset(unsigned char n);
void OLED_set_display_clock(unsigned char n);
void OLED_set_precharge_period(unsigned char n);
void OLED_set_common_config(unsigned char n);
void OLED_set_VCOMH(unsigned char n);
void OLED_set_NOP();
void OLED_cursor(unsigned char x_pos, unsigned char y_pos);
void OLED_print_char(unsigned char x_pos, unsigned char y_pos, unsigned char ch);
void OLED_print_string(unsigned char x_pos, unsigned char y_pos, unsigned char *ch);
void OLED_draw_bitmap(unsigned char xb, unsigned char yb, unsigned char xe, unsigned char ye, unsigned char *bmp);
void OLED_print_chr(unsigned char x_pos, unsigned char y_pos, signed char value);
void OLED_print_int(unsigned char x_pos, unsigned char y_pos, signed long value);
void OLED_print_decimal(unsigned char x_pos, unsigned char y_pos, unsigned long value, unsigned char points);
void OLED_print_float(unsigned char x_pos, unsigned char y_pos, float value, unsigned char points);
SSD1306.c
| Code: | #include "SSD1306.h"
#include "fonts.c"
void OLED_init()
set_TRIS_B(0xF0);
port_B_pullups(FALSE);
output_high(D0);
output_low(RST);
delay_ms(60);
output_high(RST);
OLED_set_display_on_off(0x00);
OLED_set_display_clock(0x80);
OLED_set_multiplex_ratio(0x3F);
OLED_set_display_offset(0x00);
OLED_set_start_line(0x00);
OLED_set_charge_pump(Enable_Charge_Pump);
OLED_set_addressing_mode(Page_Addressing_Mode);
OLED_set_segment_remap(Column_Address_0_Mapped_to_SEG127);
OLED_set_common_output_scan_direction(Scan_from_COM63_to_0);
OLED_set_common_config(0x10);
OLED_set_contrast(0xCF);
OLED_set_precharge_period(0xF1);
OLED_set_VCOMH(0x40);
OLED_set_entire_display_on(Normal_Display);
OLED_set_normal_or_inverse_display(Non_Inverted_Display);
OLED_set_display_on_off(Display_ON);
OLED_fill(0x00);
OLED_gotoxy(0,0);
unsigned char s = 8;
switch(type)
case 1:
output_high(DC);
default:
output_low(DC);
output_low(D0);
while(s > 0)
if((value & 0x80) != 0)
output_high(D1); ;
output_low(D1);
output_high(D0);
output_low(D0);
value <<= 1;
s -= 1;
OLED_write((Set_Page_Start_Address_CMD + y_pos), CMD);
OLED_write(((x_pos & 0x0F) | Set_Lower_Column_Start_Address_CMD), CMD);
OLED_write((((x_pos & 0xF0) >> 0x04) | Set_Higher_Column_Start_Address_CMD), CMD);
unsigned char x_pos = 0;
unsigned char page = 0;
for(page = 0; page <= 7; page++)
OLED_write((Set_Page_Start_Address_CMD + page), CMD);
OLED_write(Set_Lower_Column_Start_Address_CMD, CMD);
OLED_write(Set_Higher_Column_Start_Address_CMD, CMD);
for(x_pos = 0; x_pos <= 127; x_pos++)
OLED_write(bmp_data, DAT);
OLED_fill(0x00);
OLED_write(Set_Lower_Column_Start_Address_CMD + (n % 16), CMD);
OLED_write(Set_Higher_Column_Start_Address_CMD + (n / 16), CMD);
OLED_write(Set_Memory_Addressing_Mode_CMD, CMD);
OLED_write(n, CMD);
OLED_write(Set_Column_Address_CMD, CMD);
OLED_write(r, CMD);
OLED_write(t, CMD);
OLED_write(Set_Page_Address_CMD, CMD);
OLED_write(r, CMD);
OLED_write(t, CMD);
OLED_write((Set_Display_Start_Line_CMD | n), CMD);
OLED_write(Set_Contrast_Control_CMD, CMD);
OLED_write(n, CMD);
OLED_write(Set_Charge_Pump_CMD, CMD);
OLED_write((Set_Higher_Column_Start_Address_CMD | n), CMD);
OLED_write((Set_Segment_Remap_CMD | n), CMD);
OLED_write((Set_Entire_Display_ON_CMD | n), CMD);
OLED_write((Set_Normal_or_Inverse_Display_CMD | n), CMD);
OLED_write(Set_Multiplex_Ratio_CMD, CMD);
OLED_write(n, CMD);
OLED_write((Set_Display_ON_or_OFF_CMD + n) , CMD);
OLED_write((Set_Page_Start_Address_CMD | n), CMD);
OLED_write((Set_COM_Output_Scan_Direction_CMD | n), CMD);
OLED_write(Set_Display_Offset_CMD, CMD);
OLED_write(n, CMD);
OLED_write(Set_Display_Clock_CMD, CMD);
OLED_write(n, CMD);
OLED_write(Set_Pre_charge_Period_CMD, CMD);
OLED_write(n, CMD);
OLED_write(Set_Common_HW_Config_CMD, CMD);
OLED_write((0x02 | n), CMD);
OLED_write(Set_VCOMH_Level_CMD, CMD);
OLED_write(n, CMD);
void OLED_set_NOP()
OLED_write(Set_NOP_CMD, CMD);
unsigned char i = 0;
if(y_pos != 0)
if(x_pos == 1)
OLED_gotoxy(0x00, (y_pos + 0x02));
OLED_gotoxy((0x50 + ((x_pos - 0x02) * 0x06)), (y_pos + 0x02));
for(i = 0; i < 6; i++)
OLED_write(0xFF, DAT);
unsigned char chr = 0;
chr = (ch - 32);
if(x_pos > 122)
x_pos = 0;
y_pos++;
OLED_gotoxy(x_pos, y_pos);
OLED_write(font_regular[chr][i], DAT);
unsigned char j = 0;
while(ch[j] != '\0')
chr = (ch[j] - 32);
if(x_pos > 126)
x_pos = 0;
y_pos++;
j++;
x_pos += 6;
unsigned long i = 0;
unsigned char y_pos = 0;
for(y_pos = yb; y_pos <= ye; y_pos++)
OLED_gotoxy(xb, y_pos);
for(x_pos = xb; x_pos < xe; x_pos++)
OLED_write((bmp[i]), DAT);
i++;
unsigned char ch = 0;
if(value < 0)
OLED_print_char(x_pos, y_pos, '-');
value = -value;
OLED_print_char(x_pos, y_pos,' ');
ch = (value / 100);
OLED_print_char((x_pos + 6), y_pos , (48 + ch));
ch = ((value % 100) / 10);
OLED_print_char((x_pos + 12), y_pos , (48 + ch));
ch = (value % 10);
OLED_print_char((x_pos + 18), y_pos , (48 + ch));
if(value < 0)
value = -value;
if(value > 9999)
ch = (value / 10000);
ch = ((value % 10000)/ 1000);
ch = ((value % 1000) / 100);
OLED_print_char((x_pos + 24), y_pos , (48 + ch));
ch = (value % 10);
OLED_print_char((x_pos + 30), y_pos , (48 + ch));
else if((value > 999) && (value <= 9999))
ch = (value % 10);
else if((value > 99) && (value <= 999))
ch = (value % 10);
else if((value > 9) && (value <= 99))
ch = (value % 10);
ch = (value % 10);
OLED_print_char(x_pos, y_pos, '.');
ch = (value / 1000);
if(points > 1)
if(points > 2)
if(points > 3)
ch = (value % 10);
signed long tmp = 0;
OLED_print_int(x_pos, y_pos, value);
tmp = value;
tmp = abs((value - tmp) * 10000);
if((abs(value) >= 9999) && (abs(value) < 99999))
OLED_print_decimal((x_pos + 36), y_pos, tmp, points);
else if((abs(value) >= 999) && (abs(value) < 9999))
OLED_print_decimal((x_pos + 30), y_pos, tmp, points);
else if((abs(value) >= 99) && (abs(value) < 999))
OLED_print_decimal((x_pos + 24), y_pos, tmp, points);
else if((abs(value) >= 9) && (abs(value) < 99))
OLED_print_decimal((x_pos + 18), y_pos, tmp, points);
else if((abs(value) >= 0.00009) && (abs(value) < 9))
OLED_print_decimal((x_pos + 12), y_pos, tmp, points);
fonts.c
const unsigned char font_regular[92][6] =
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // sp
0x00, 0x00, 0x00, 0x2f, 0x00, 0x00, // !
0x00, 0x00, 0x07, 0x00, 0x07, 0x00, // "
0x00, 0x14, 0x7f, 0x14, 0x7f, 0x14, // #
0x00, 0x24, 0x2a, 0x7f, 0x2a, 0x12, // $
0x00, 0x62, 0x64, 0x08, 0x13, 0x23, // %
0x00, 0x36, 0x49, 0x55, 0x22, 0x50, // &
0x00, 0x00, 0x05, 0x03, 0x00, 0x00, // '
0x00, 0x00, 0x1c, 0x22, 0x41, 0x00, // (
0x00, 0x00, 0x41, 0x22, 0x1c, 0x00, // )
0x00, 0x14, 0x08, 0x3E, 0x08, 0x14, // *
0x00, 0x08, 0x08, 0x3E, 0x08, 0x08, // +
0x00, 0x00, 0x00, 0xA0, 0x60, 0x00, // ,
0x00, 0x08, 0x08, 0x08, 0x08, 0x08, // -
0x00, 0x00, 0x60, 0x60, 0x00, 0x00, // .
0x00, 0x20, 0x10, 0x08, 0x04, 0x02, // /
0x00, 0x3E, 0x51, 0x49, 0x45, 0x3E, // 0
0x00, 0x00, 0x42, 0x7F, 0x40, 0x00, // 1
0x00, 0x42, 0x61, 0x51, 0x49, 0x46, // 2
0x00, 0x21, 0x41, 0x45, 0x4B, 0x31, // 3
0x00, 0x18, 0x14, 0x12, 0x7F, 0x10, // 4
0x00, 0x27, 0x45, 0x45, 0x45, 0x39, // 5
0x00, 0x3C, 0x4A, 0x49, 0x49, 0x30, // 6
0x00, 0x01, 0x71, 0x09, 0x05, 0x03, // 7
0x00, 0x36, 0x49, 0x49, 0x49, 0x36, // 8
0x00, 0x06, 0x49, 0x49, 0x29, 0x1E, // 9
0x00, 0x00, 0x36, 0x36, 0x00, 0x00, // :
0x00, 0x00, 0x56, 0x36, 0x00, 0x00, // ;
0x00, 0x08, 0x14, 0x22, 0x41, 0x00, // <
0x00, 0x14, 0x14, 0x14, 0x14, 0x14, // =
0x00, 0x00, 0x41, 0x22, 0x14, 0x08, // >
0x00, 0x02, 0x01, 0x51, 0x09, 0x06, // ?
0x00, 0x32, 0x49, 0x59, 0x51, 0x3E, // @
0x00, 0x7C, 0x12, 0x11, 0x12, 0x7C, // A
0x00, 0x7F, 0x49, 0x49, 0x49, 0x36, // B
0x00, 0x3E, 0x41, 0x41, 0x41, 0x22, // C
0x00, 0x7F, 0x41, 0x41, 0x22, 0x1C, // D
0x00, 0x7F, 0x49, 0x49, 0x49, 0x41, // E
0x00, 0x7F, 0x09, 0x09, 0x09, 0x01, // F
0x00, 0x3E, 0x41, 0x49, 0x49, 0x7A, // G
0x00, 0x7F, 0x08, 0x08, 0x08, 0x7F, // H
0x00, 0x00, 0x41, 0x7F, 0x41, 0x00, // I
0x00, 0x20, 0x40, 0x41, 0x3F, 0x01, // J
0x00, 0x7F, 0x08, 0x14, 0x22, 0x41, // K
0x00, 0x7F, 0x40, 0x40, 0x40, 0x40, // L
0x00, 0x7F, 0x02, 0x0C, 0x02, 0x7F, // M
0x00, 0x7F, 0x04, 0x08, 0x10, 0x7F, // N
0x00, 0x3E, 0x41, 0x41, 0x41, 0x3E, // O
0x00, 0x7F, 0x09, 0x09, 0x09, 0x06, // P
0x00, 0x3E, 0x41, 0x51, 0x21, 0x5E, // Q
0x00, 0x7F, 0x09, 0x19, 0x29, 0x46, // R
0x00, 0x46, 0x49, 0x49, 0x49, 0x31, // S
0x00, 0x01, 0x01, 0x7F, 0x01, 0x01, // T
0x00, 0x3F, 0x40, 0x40, 0x40, 0x3F, // U
0x00, 0x1F, 0x20, 0x40, 0x20, 0x1F, // V
0x00, 0x3F, 0x40, 0x38, 0x40, 0x3F, // W
0x00, 0x63, 0x14, 0x08, 0x14, 0x63, // X
0x00, 0x07, 0x08, 0x70, 0x08, 0x07, // Y
0x00, 0x61, 0x51, 0x49, 0x45, 0x43, // Z
0x00, 0x00, 0x7F, 0x41, 0x41, 0x00, // [ 91
0x00, 0x02, 0x04 , 0x08, 0x10, 0x20, // \92
0x00, 0x00, 0x41, 0x41, 0x7F, 0x00, // ]
0x00, 0x04, 0x02, 0x01, 0x02, 0x04, // ^
0x00, 0x40, 0x40, 0x40, 0x40, 0x40, // _
0x00, 0x00, 0x01, 0x02, 0x04, 0x00, // '
0x00, 0x20, 0x54, 0x54, 0x54, 0x78, // a
0x00, 0x7F, 0x48, 0x44, 0x44, 0x38, // b
0x00, 0x38, 0x44, 0x44, 0x44, 0x20, // c
0x00, 0x38, 0x44, 0x44, 0x48, 0x7F, // d
0x00, 0x38, 0x54, 0x54, 0x54, 0x18, // e
0x00, 0x08, 0x7E, 0x09, 0x01, 0x02, // f
0x00, 0x18, 0xA4, 0xA4, 0xA4, 0x7C, // g
0x00, 0x7F, 0x08, 0x04, 0x04, 0x78, // h
0x00, 0x00, 0x44, 0x7D, 0x40, 0x00, // i
0x00, 0x40, 0x80, 0x84, 0x7D, 0x00, // j
0x00, 0x7F, 0x10, 0x28, 0x44, 0x00, // k
0x00, 0x00, 0x41, 0x7F, 0x40, 0x00, // l
0x00, 0x7C, 0x04, 0x18, 0x04, 0x78, // m
0x00, 0x7C, 0x08, 0x04, 0x04, 0x78, // n
0x00, 0x38, 0x44, 0x44, 0x44, 0x38, // o
0x00, 0xFC, 0x24, 0x24, 0x24, 0x18, // p
0x00, 0x18, 0x24, 0x24, 0x18, 0xFC, // q
0x00, 0x7C, 0x08, 0x04, 0x04, 0x08, // r
0x00, 0x48, 0x54, 0x54, 0x54, 0x20, // s
0x00, 0x04, 0x3F, 0x44, 0x40, 0x20, // t
0x00, 0x3C, 0x40, 0x40, 0x20, 0x7C, // u
0x00, 0x1C, 0x20, 0x40, 0x20, 0x1C, // v
0x00, 0x3C, 0x40, 0x30, 0x40, 0x3C, // w
0x00, 0x44, 0x28, 0x10, 0x28, 0x44, // x
0x00, 0x1C, 0xA0, 0xA0, 0xA0, 0x7C, // y
0x00, 0x44, 0x64, 0x54, 0x4C, 0x44, // z
0x14, 0x14, 0x14, 0x14, 0x14, 0x14 // horizontal lines
Example:
| Code: | #include <16F876A.h>
#device *= 16
#fuses NOWDT, HS, PROTECT, CPD, PUT, BROWNOUT
#use delay (clock = 10MHz)
#include "SSD1306.c"
void setup();
signed long i = -9;
float f = 0;
setup();
f += 1.1;
i++;
if(i > 1000)
i = -9;
f = 0;
OLED_print_float(1, 4, f, 1);
OLED_print_int(1, 5, i);
delay_ms(600);
void setup()
char text[] = {"MicroArena"};
disable_interrupts(global);
setup_ADC(ADC_off);
setup_ADC_ports(no_analogs);
setup_CCP1(CCP_off);
setup_CCP2(CCP_off);
setup_SPI(SPI_disabled | SPI_SS_disabled);
setup_timer_0(T0_internal);
setup_timer_1(T1_disabled);
setup_timer_2(T2_disabled, 255, 1);
set_timer0(0);
set_timer1(0);
set_timer2(0);
OLED_init();
OLED_print_string(34, 2, text);
https://www.youtube.com/watch?v=w4L1xaYNdDw _________________ https://www.facebook.com/MicroArena
SShahryiar
