PGM Pin
SeeCwriter
PGM Pin
PostPosted: Thu Feb 26, 2015 10:56 am     Reply with quote
The 18F87J60 does not have an identified PGM pin. What pin should I connect the ICD pin 6 (DIAG) to on the CPU?
PostPosted: Fri Feb 27, 2015 12:24 am     Reply with quote
http://www.ccsinfo.com/faq.php?page=connect_icd
Pin B3 is an optional pin connected to the ICD-S/U that allows use of the
monitor feature while debugging. If pin B3 is used in the target circuit or
is not connected to the ICD-S/U, the target can still be programmed and
debugged, except without use of the monitor feature. When debugging,
disabling the userstream feature will ignore the connection between pin 1
on the ICD-S/U and pin 6 on the target device. Older versions of the
debugger software require that if the monitor is not used, the pin
connection on the ICD connector needs to be pulled high at all times.
While pin B3 is recommended for the monitor feature, any pin on a PICĀ®
MCU or PICĀ® DSC can support this feature.
