32K Sram driver for 16F / 18F etc Pics
asmboy
PostPosted: Fri Feb 06, 2015 6:08 pm     Reply with quote
refer to this file for a schematic.
was originally tested with 18f8722 using port F and port D
using a 16.5888mhz clock
https://commons.wikimedia.org/wiki/File:SRAM32ka.pdf
The driver is semi flexible and was used to stream blocks of 16bit ADC
data into temporary storage at 2k samples per second, for later transmission to a host system - after a timed sample capture is complete.
a one second, 16it ADC capture fills one bank.
it works - but no claim to elegance is included.
suggestions for improvement welcome....
// SRAM driver for 32k x8 fast Sram
// tested  with 18F8722 using port D and F
// port f =control port d =data xfer Bi-Di
#use fast_io(D)
#use fast_io(F);
set_tris_d(255);
set_tris_f(0);
byte XportF =0b00011101;
unsigned int16 absmemaddr=0;
unsigned int8  membank=0;
#bit  notclk=Xportf.0
#bit  cntRST=Xportf.1
#bit  notWEN=Xportf.2
#bit  notOEN=Xportf.3
#bit  notCCE=Xportf.4
#define M_CLk    pin_F0
#define M_reset  pin_F1
#define M_notWE  pin_F2
#define M_notOE  pin_F3
#define M_notCE  pin_f4
// set bank 0-7 of 4096 bytes each
// autowrap occurs
void setmembank(int8 bnum){
      bnum&=7; // mask all but 8 banks worth
      membank=bnum;  XportF &=0b00011111; // keep low order
      bnum <<=5;   // shift to mask back  where it belongs
      XportF |=bnum;     // plug in new membank
      output_F(xportf);
// the argument decides to reset within current bank
// or reset to bank 0 AND  counter zero
#inline
void memaddRST (int1 bank_reset ){
      int1 dosw;
      if(0==notcce){ dosw=1; notCCE=1;} // disable sram
      notclk=1;       // default clock to ready to lower
      delay_cycles(2);      cntrst=1;
      output_F(xportf);     cntrst=0;
      output_F(xportf);
      if(dosw) notCCE=0; // re enable the mem chip if deselected
      output_F(xportf);   absmemaddr=0;       // reset present counter
      if(bank_reset) {  setmembank(0);  membank=0;   output_F(xportf); }
#inline
//   increment Sram address by one byte
void memaddinc ( void ){
      output_low(M_clk);    //notclk=0;
      absmemaddr++;         // creates a useful clock -low delay time
      output_high(M_clk);   // notclk=1;
      // test: did we just step out of present bank ?
      if (absmemaddr>4095){    // add rollover bank switch here
          memaddRST (0);   ++membank;  setmembank(membank);
//  spans 0 to 32767  8 blocks of 4096
//  sets an arbitrary SRAM address
void gotoaddress( unsigned int16 w){
       int8 nubank=0;  memaddRST (1); // go to base 0 of bank 0
       while (w>4095){ nubank++;  w-=4096;}
       setmembank(nubank);
       while(w){
         --w;
// converts negative logic of chip to positive
//     chipon =1,  enable chip
//            =0,  disable
//     does not tamper with address setting etc
void mCHIPenable ( int1 chipon ){
      set_tris_d(255);  // insure in deflt state
      if (chipon) notcce=0;
      else        notcce=1;
      output_F(xportf);
//  setup and zero mem chip
void setup_mem(void){
     mCHIPenable(0);      memaddRST(1);      mCHIPenable(1);
// read/write is in flat space , spanning banks as absolute address
// 0 - 32767 if you just write or read consecutively
void writenextbyte (byte  next ){
      output_d(next);
      set_tris_d(0);  // insure in deflt state
      output_low(M_notWE);     delay_cycles(2);    output_high(M_notWE);
      set_tris_d(255);  // insure in deflt state of INPUT
      memaddinc();
void writenextWord (int16  next ){
      output_d(make8(next,0));
      memaddinc();
      output_d(make8(next,1));
      memaddinc();
// this is serial read with bank boundary autoselect
byte readnextbyte(void){
     byte x;  //output data enable
     output_low(M_notOE);    delay_cycles(2);   x=input_d();
     output_high(M_notOE);   memaddinc();       return (x);
int16 readnextword(void){
     byte x,y;  //output data enable
     output_low(M_notOE);    delay_cycles(2);   y=input_d();
     return (make16(y,x));
