kaushalpatel7786
| PIC18F25K80 not in Device List |
Posted: Mon Dec 05, 2016 2:25 pm |
| I have CCS 4.107 version. Can anyone please share device 18F25K80.h file? |
Posted: Mon Dec 05, 2016 2:33 pm |
The .h file will not add support for a device. All it is is basic defines that can be copied from other chips. The actual support for a chip is much deeper inside the compiler. You will need to update to get this.
It is possible to add a device if your compiler supports one that is very similar, using the device editor in the iDE, but it is a lot of work. |
Joined: 01 Jul 2010 Posts: 9597 Location: Greensville,Ontario
Posted: Mon Dec 05, 2016 4:04 pm |
| The other alternative is to choose a PIC that your version of compiler supports. There are a LOT of PICs available, do you NEED that particular one ? |
kaushalpatel7786
Posted: Tue Dec 06, 2016 7:11 am |
| temtronic wrote: | | The other alternative is to choose a PIC that your version of compiler supports. There are a LOT of PICs available, do you NEED that particular one ? |
Thank you for advise, but I have to use this PIC only. |
kaushalpatel7786
Posted: Tue Dec 06, 2016 7:13 am |
| Ttelmah wrote: | The .h file will not add support for a device. All it is is basic defines that can be copied from other chips. The actual support for a chip is much deeper inside the compiler. You will need to update to get this.
I agree with you that it is a lot of work to edit in any existing device, so i finally decide to update the software. Thank you for advise. |
