Timer1 as counter.
Ventouza
Timer1 as counter.
PostPosted: Mon Apr 21, 2014 3:01 am     Reply with quote
Hi there,
this is my first post so be patient.
I try to collect pulses through the RC0 gate but nothing happens.
The input pulses created from a button with a resistance in pull down connection. And if the pulses >= 1 i want to switch a led on.
It doesn't work for me and i don't know what else i have to do.
I use 4.093 version and the development board ql200.
Here is the code
#include <16F877A.h>
#FUSES XT                       //High speed Osc (> 4mhz)
unsigned int16 a;
   setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1);
      set_timer1(0);
      a=get_timer1();
      if(a>= 1)
      output_high(pin_c7);
      else output_low(pin_c7);
asmboy
PostPosted: Mon Apr 21, 2014 6:59 am     Reply with quote
make sure your pic is RUNNING first!
try this in main:
      output_toggle (pin_c7);
does the pin change every 1/2 second or not??
Ventouza
PostPosted: Mon Apr 21, 2014 8:19 am     Reply with quote
Yes my pic is running but i found my crystal was gone.
So it was a hardware problem. Now with new crystal the program is running perfectly.
Thanks asmboy
