problem dspic33fj64gp804 with SPI
John22
PostPosted: Wed Apr 16, 2014 1:35 pm     Reply with quote
I have a problem to choose the right pins which i need to use for an SPI application using the dspic33fj64gp804
(I have a already read the datasheet but i have confused )
i need your advices please
jeremiah
PostPosted: Wed Apr 16, 2014 1:45 pm     Reply with quote
You need to pick pins that have an RP designator on them: RP1, RP2, etc. You can see these listed in the pin diagrams in the data sheet.
In your software, you simply need to use the #pin_select directive to set which pins you chose.
