justincdas@gmail.com
| Need help........ |
Posted: Mon Jan 13, 2014 4:53 am |
i am using ccs 5 compiler , for pic16f877a, i have problems with adc
when i use this pre processor directive "#DEVICE ADC=10" it showing error , is there any other options for using 10 bit resolution adc.. plese help me.......... |
Posted: Mon Jan 13, 2014 8:13 am |
#DEVICE ADC=10, is correct
Key is though it must be right at the top of the code. So:
#include <16F877A.h>
#device ADC=10
It _won't_ be accepted, if it is after other things. It'll work after the fuses, but not after the delay, and/or the RS232 declaration.
