| canavaroski90
				| MAX7219 Without SPI - Easy To Use |
				|  Posted: Wed May 16, 2012 5:17 am |   |
				| Refer this pdf to assemble your circuit: http://www.rasmicro.com/FTP/MAX7219-21%208-Digit%20LED%20Display%20Driver.pdf
 You can directly download from here:
 http://www.sendspace.com/file/mkufgq
 Or you can look over and copy the library from here:
  	  | Code: |  	  | /* ******************************************************************************************************
 * Chip        : MAX7219
 * Author      : Burak HANÇERLİ
 * Mail        : bhancerli@gmail.com
 * Description : MAX7219 LED Display Driver Routines - v1.1
 *  The Maxim MAX7219 is a led display driver. It can control up to 64 individual leds or eight
 *  7-segment-display.
 *  Max7912 uses 3-wire to communicate with microcontroller.
 *    - DATA   : Used to transmit data.
 *    - CLOCK  : Used to generate clock signal which is required for transmitting each bite of data.
 *    - LOAD   : Used to load data to the Max7913's Dual-Port SRam.
 *  Advantages of Max7219 :
 *  - Adjustable intensity. (More or less bright leds)
 *  - Shutdown mode (much less power consumption)
 *  - Test mode (To see if digits are working or not)
 *  - Adjustable digit number. (1 to 8 seven-segment-display)
 *  - Changeable decode mode. (codeB-decode-mode or no-decode-mode)
 *      (Look over datasheet for more detailed information)
 *  DESCRIPTION OF USER FUNCTIONS
 *  init7219()                      : Required for initialize MAX7219. This function have has to be called before calling any function.
 *  write7219(digit, data)          : Writes data to the specified digit number. If Decimal Point needed on any digit, just add
 128 to the data.
 For example : write7219(1,3)   = writes "3"  to first digit.
 write7219(1,131) = writes "3." to first digit.
 *  shutdown7219(operatingMode)     : Set operatingMode = 0 to Shutdown mode
 *                                    Set operatingMode = 1 to Normal mode
 *  decode7219(decodeMode)          : Sets digit-decode mode. code-B or no-decode mode. Look up datasheet for detailed instructions.
 *                                    For example, if user sets decodeMode = 4, (4=0b00000100), then 3. digit will be
 *                                    decoded as code-B algorithm, but other pins don't have any decode mode.
 *  brightness7219(brightnessLevel) : Sets brightness level of digits.
 *                                    brightnessLevel = 0  ; minimum brightness level
 *                                    brightnessLevel = 15 ; maximum brigthness level
 *  scanLimit7219(totalDigitNumber) : Sets number of connected digits to the MAX7219. When init7912() function is called,
 number of digit will be setted to 4 as default.
 *  test7219(testMode)              : Sets 7-segment-display test-mode on or off.
 testMode = 0 ; normal operation mode
 testMode = 1 ; display test mode
 ** THIS LIBRARY CAN BE USED, DEVELOPED OR SHARED WITH REFERRING THE AUTHOR.
 // CONSTANTS //
 // - Connection Pins (CHANGE THESE PINS AS YOU WISH)
 #define CLK       PIN_A2
 #define LOAD      PIN_A1
 #define SEND_DATA PIN_A0
 // - Mode Selection
 #define decode 0x09
 #define brightness 0x0A
 #define scanLimit 0x0B
 #define shutDown 0x0C
 #define dispTest 0x0F
 // Firt 4 bites (not used generally)
 #define firstBites 0x0
 // Wait function
 #define wait delay_ms(1)
 long serialData=0;
 void clock7219() // clock (CLK) pulse
 output_low(CLK);
 wait;
 output_high(CLK);
 void load7219()  // load (LOAD) pulse
 output_low(LOAD);
 wait;
 output_high(LOAD);
 void send7219(long data) // send 16 bit data word to the 7219
 int count;
 for (count=0; count<16; ++count)
 output_bit(SEND_DATA, shift_left(&data,2,0)); // set data (DIN) level
 clock7219(); // clock data in
 load7219(); // latch the last 16 bits clocked
 void dataMaker(byte mode, int dataIncoming) // Standart data package function
 serialData=firstBites;
 serialData<<=4;
 serialData|=mode;
 serialData<<=8;
 serialData|=dataIncoming;
 send7219(serialData);
 void write7219(byte digit, int data) // Send data to digits
 dataMaker(digit, data);
 void shutdown7219(int operatingMode)
 dataMaker(shutDown,operatingMode);
 void decode7219(int decodeMode)
 dataMaker(decode, decodeMode);
 void brightness7219(int brightnessLevel)
 dataMaker(brightness, brightnessLevel);
 void scanLimit7219(int totalDigitNumber)
 dataMaker(scanLimit, totalDigitNumber);
 void test7219(int testMode)
 dataMaker(dispTest, testMode);
 void init7219()
 dataMaker(shutDown, 1);     // No-Shutdown mode. Normal Operation mode.
 dataMaker(decode, 15);      // All digits are programmed as code-B decode mode.
 dataMaker(scanLimit, 4);    // Total digit number set to 4.
 dataMaker(brightness, 15);  // Full brightness.
 Liberate your mind..
