real time clock
pkipyy
real time clock
PostPosted: Sun Dec 15, 2013 10:13 am     Reply with quote
I revised command delay time.
I used 500kHz internal oscillator for clock source.
Also this code shows how to use watch dog timer.
#include <16f1937.h>
#use delay(clock = 500000)
#fuses NOLVP,WDT
#byte PORTB =0x0d
#byte PORTC = 0x0e //PORTC
#byte TRISB = 0x8d
#byte TRISC = 0x8e
#byte LAtC = 0x10E
#byte OPTION_REG = 0x95
#byte OSCCON = 0x99
#byte INTCON = 0x0b
#byte TMR0 =0x15
#define IS_LEAP(year) (year%4 == 0)
int ticker=0;
int msec_100=0;
int minutes=0;
int hours=0;
int seconds=0;
int days=1;
int month=1;
int year=1;
#INT_TIMER0
void isr_timer0()
   #asm
   nop;
   #endasm
   set_rtcc(0xff-250+11);//4msec
   ticker++;
   if(ticker==25)     //100msec
      msec_100++;
      ticker=0;
   if(msec_100==10) //1 sec
      seconds++;
      msec_100=0;
   if(seconds==60) seconds=0;
   OPTION_REG=0x00;
   //OSCCON=0x3a;
   setup_counters(rtcc_internal,rtcc_div_2);
   INTCON=0xa0;
   TRISB=0;
   setup_wdt(WDT_2S);
      restart_wdt();
      if(seconds%2) PORTB=1;
      else PORTB=0;
Gabriel
PostPosted: Sun Dec 15, 2013 8:15 pm     Reply with quote
I would give user ckielstra some credit since your work is a variation or improvement on his.
Other than that, thanks for sharing.
G.
CCS PCM 5.078 & CCS PCH 5.093
pkipyy
I did coding myself!!
PostPosted: Wed Dec 18, 2013 2:43 am     Reply with quote
I copied only part of year,month,day.
It is similar whoever did.
I revised my own code.
Now I deleted part of day,year,month.
What is variation?
Worth of this code is Only knowing man can see.
How correct time!
