Counter with lcd
Kumara
Counter with lcd
PostPosted: Thu Oct 17, 2013 10:49 am     Reply with quote
This will help for beginners. Lcd.c driver is available in Picc\Drivers (CCS C Compiler).
// Program function: Digital counter with LCD.
// Target processor 16F877A (20 MHZ)
// Written by Kumara
#include <16F877A.h>              // Pic Microcontroller (MCU)
#DEVICE ADC=10                    // 8 Bit analog resolution
#fuses NOWDT,HS, NOPUT, NOPROTECT // Fuses
#fuses NOBROWNOUT, NOLVP          // Fuses
#use delay(clock=20000000)        // Crystal Oscillator Frequency ( 20 MHZ)
#include <lcd.c>                  // Driver for LCD Module ( PICC\DRIVERS )
   void main()                    // Main block
   INT16 PRE_COUNT=0;             // Declare variable
   INT16 SET_COUNT;               // Declare variable
   INT1 SW1;                      // Declare variable
   BOOLEAN ISPRESSED=FALSE;       // Boolean logic=0;
   setup_adc_ports(AN0);
   while (TRUE) {                // Endless loop
   SW1=INPUT(PIN_C0);            // Positive inputs
         IF(PRE_COUNT==0)
         lcd_putc("\f");         // LCD clear
         lcd_gotoxy(1,1);        // Select Raw 1 & start digit 1 position
         printf(lcd_putc," PRE_COUNT:%04LU ",PRE_COUNT);
         lcd_gotoxy(1,2);        // Select Raw 2 & start digit 1 position
         printf(lcd_putc," SET_COUNT:%04LU ",SET_COUNT);
         DELAY_MS(200);
         SET_ADC_CHANNEL(0);     // INPUT AN0
         DELAY_US(100);
         SET_COUNT=READ_ADC();   // SET VALUE= RA1 ( 10K V/R )
         SET_COUNT=(SET_COUNT);  // FOR 4 DIGITS UP TO 1023
         IF (SW1 && !ISPRESSED)
         DELAY_MS(10);
         SW1=INPUT(PIN_A1);
         IF(SW1)
         {PRE_COUNT++;
         ISPRESSED=TRUE;
         DELAY_MS(100);
         IF(PRE_COUNT>=SET_COUNT)
            OUTPUT_HIGH(PIN_B0);
         ELSE
            OUTPUT_LOW(PIN_B0);
         IF(!SW1)                 // This line must be here
         ISPRESSED=FALSE;         // This line must be here
