FLEX I2C Memory Driver
KONAMI
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Fri Sep 06, 2013 9:41 am     Reply with quote
This is CCS C 2464 Driver that i just modify. Modifications allow you to use many memory in the same I2C bus. Each memory should have it hardware address. For example if we want to use 8 Memory, We have to use this combination of bits.
E2 E1 E0
0 0 0 Memory0 (dev adr=00)
1 1 1 Memory7 (dev adr=7)
////   Library for a 24LC64 serial EEPROM                              ////
////   init_ext_eeprom();    Call before the other functions are used  ////
////   write_ext_eeprom(a, d);  Write the byte d to the address a      ////
////   d = read_ext_eeprom(a);   Read the byte d from the address a    ////
////   The main program may define eeprom_sda                          ////
////   and eeprom_scl to override the defaults below.                  ////
////        (C) Copyright 1996,2003 Custom Computer Services           ////
//// This source code may only be used by licensed users of the CCS C  ////
//// compiler.  This source code may only be distributed to other      ////
//// licensed users of the CCS C compiler.  No other use, reproduction ////
//// or distribution is permitted without written permission.          ////
//// Derivative programs created using this software in object code    ////
//// form are not restricted in any way.                               ////
#ifndef EEPROM_SDA
#define EEPROM_SDA  PIN_C1
#define EEPROM_SCL  PIN_C0
#use i2c(master, sda=EEPROM_SDA, scl=EEPROM_SCL)
#define EEPROM_ADDRESS long int
#define EEPROM_SIZE   8192
void init_ext_eeprom()
   output_FLOAT(EEPROM_SCL);
   output_FLOAT(EEPROM_SDA);
void write_ext_eeprom(long int address, BYTE data,int dev_adr)
   short int status;
   i2c_start();
   i2c_write(0xa0|dev_adr<<1);
   i2c_write(((address>>8)&0x1f)|dev_adr<<5);
   i2c_write(address);
   i2c_write(data);
   i2c_stop();
   i2c_start();
   status=i2c_write(0xa0|dev_adr<<1);
   while(status==1)
      i2c_start();
   i2c_stop();
BYTE read_ext_eeprom(long int address,int dev_adr) {
   BYTE data;
   i2c_start();
   i2c_write(address);
   i2c_start();
   i2c_write(0xa1|dev_adr<<1);
   data=i2c_read(0);
   i2c_stop();
   return(data);
Now how to use it?
To write/read at memory with dev_adr=00, this is the code
dev_adr=0;
 write_ext_eeprom(adress, data,dev_adr);// adress: where you will write Byte data,dev_adr is the Hardware adress
Enjoy.
