micro_debugger
| PIC18F25K20 comparator not working - PLS HELP |
Posted: Fri Jul 26, 2013 6:36 pm |
Compiles 5.010 but tested also with 4.141
PIC18F25K20
Comparator is not working. COUT is always high or if inverted always low. If it is low fires interrupts as should be. I printed all registers after setup, seems to be set correctly. No idea anymore, may be somebody can take a look on it, I maybe something missing. Part of the listing
setup_adc(ADC_CLOCK_DIV_4 | ADC_TAD_MUL_16);
setup_adc_ports(sAN12|sAN11|sAN9|sAN8|sAN2|sAN1|VSS_VDD);
setup_comparator(CP1_A1_VREF | CP1_FAST)
setup_vref(VREF_HIGH | 15 );
C1RSEL=1; // set manually - compiler not set it ( ???)
if(C1OUT)
printf(bputc,"\n\rLOW");
printf(bputc,"\n\rHIGH");
always the result is high or low (if inverted)
I add the following lines in order to check what is set by compiler in registers
printf(bputc,"\n\r\n\rCM1CON0 C1ON:%x", C1ON);
printf(bputc,"\n\rCM1CON0 C1OUT:%x", C1OUT);
printf(bputc,"\n\rCM1CON0 C1OE:%x", C1OE);
printf(bputc,"\n\rCM1CON0 C1POL:%x", C1POL);
printf(bputc,"\n\rCM1CON0 C1SP:%x", C1SP);
printf(bputc,"\n\rCM1CON0 C1R:%x", C1R);
printf(bputc,"\n\rCM1CON0 C1CH1:%x", C1CH1);
printf(bputc,"\n\rCM1CON0 C1CH0:%x\n\r", C1CH0);
printf(bputc,"\n\rCVRCON CVREN:%x", CVREN);
printf(bputc,"\n\rCVRCON CVROE:%x", CVROE);
printf(bputc,"\n\rCVRCON CVRR:%x", CVRR);
printf(bputc,"\n\rCVRCON CVRSS:%x", CVRSS);
printf(bputc,"\n\rCVRCON CVR3:%x", CVR3);
printf(bputc,"\n\rCVRCON CVR2:%x", CVR2);
printf(bputc,"\n\rCVRCON CVR1:%x", CVR1);
printf(bputc,"\n\rCVRCON CVR0:%x\n\r", CVR0);
printf(bputc,"\n\rCM2CON1 C1RSEL:%x\n\r", C1RSEL);
printf(bputc,"\n\rCVRCON2 FVREN:%x\n\r", FVREN);
printf(bputc,"\n\rCVRCON2 FVRST:%x", FVRST);
printf(bputc,"\n\rLATA:%x\n\r", LATA);
printf(bputc,"\n\rANS1:%x\n\r", ANS1);
an the results from terminal printout are here:
CM1CON0 C1ON:01
CM1CON0 C1OUT:00
CM1CON0 C1OE:01
CM1CON0 C1POL:00
CM1CON0 C1SP:01
CM1CON0 C1R:01
CM1CON0 C1CH1:00
CM1CON0 C1CH0:01
CVRCON CVREN:01
CVRCON CVROE:00
CVRCON CVRR:00
CVRCON CVRSS:00
CVRCON CVR3:01
CVRCON CVR2:01
CVRCON CVR1:01
CVRCON CVR0:01
CM2CON1 C1RSEL:01
CVRCON2 FVREN:00
CVRCON2 FVRST:00
LATA:23
ANS1:01
I tested with voltage provided to the C12IN1- pin from 0 up to VDD (3.3 V)
always the same result.
Any idea what can I do??
Thank you in advance
Best Regards |
Posted: Sat Jul 27, 2013 12:04 am |
| Quote: | | setup_comparator(CP1_A1_VREF | CP1_FAST); |
The line above produces this ASM code in the .LST file (for both vs 4.141 and vs. 5.010):
.................... setup_comparator(CP1_A1_VREF | CP1_FAST);
0026: BCF CM2CON1.C1RSEL
0028: BCF CM2CON1.C2RSEL
002A: CLRF CM2CON0
002C: MOVLW 8D
002E: MOVWF CM1CON0
0030: MOVF TRISA,W
0032: IORLW 01 <== Bug. Sets pin A0 to an input. Should be pin A1.
0034: MOVWF TRISA
0036: MOVF TRISB,W
0038: IORLW 01 <== Bug. Pin B0 is not used by comparator.
003A: MOVWF TRISB |
To fix the TRISA bug, insert the line in bold below, after the setup_comparator() line:
| Quote: |
output_float(PIN_A1);
C1RSEL=1;
micro_debugger
Posted: Sat Jul 27, 2013 2:42 am |
Thank you so much !!!!!
You save me a lot of time!!!
I'm going to test it and keep you informed.
Warmest regards |
micro_debugger
Posted: Sat Jul 27, 2013 2:47 am |
Tested
Working perfectly.
Thank you again.
Warmest regards |
micro_debugger
Posted: Sat Jul 27, 2013 5:54 pm |
This is the final working version, I made also a small mistake in the register C1RSEL my own definition.
setup_comparator(CP1_A1_VREF | CP1_FAST | CP1_INVERT);
setup_vref(VREF_HIGH | 15);
C1RSEL=1;
Compiler is not setting up the C1RSEL to 1, and always keep it as 0, just FYI
BR |
jeremiah
Posted: Sat Jul 27, 2013 6:08 pm |
| Make sure to submit those bugs to CCS support via their email address so they get fixes in upcoming versions |
