Turning on the WDT for PIC18F66J60
stoyanoff
PostPosted: Sun Jul 28, 2013 5:19 am     Reply with quote
Greetings! I have a problem with the WDT.
Here is my program:
#include <18F66J60.h>
#FUSES HS,WDT,WDT128
#use delay(clock=10M)
   setup_wdt(WDT_ON);
   int p=RESTART_CAUSE();
I tested this program with the MPLAB SIM and in real. The result - the WDT doesn`t restart the microcontroller. In the SIM I receive a message for WDT event but there is no restart - the program continues from the while cycle! What am I doing wrong?!
PostPosted: Sun Jul 28, 2013 4:00 pm     Reply with quote
This is an MPLAB issue which you should ask on the Microchip forum,
but anyway I'll give you a hint. Go to the Debugger/Settings menu
and look at the Break Options tab and then look at WDT Timeout settings.
