MUSTANG Guest
i2c failure |
Posted: Mon Jan 06, 2003 10:23 am |
Hi, we are having much trouble getting two PIC 16F877A's to talk to each other via i2c. We just want to read information form a slave to the master.
Please could some1 have a peek at our (small) code and suggest where we are going wrong.
Using software implementation, the number we are sending from the slave to the master is F0, however, upon each iteration the number cycles, like a shift register with a bit of wire between both ends. F0, E1, C3, 87, 0F, 1F, 3E, 7C, F8, F0, E1 ......
The hardware implementation works for one interation then just outputs FF for all time.
If anyone has some CCS working PIC master-slave code we would be most grateful.
MASTER CODE
/* Standrd PIC C Headers */
#include <16f877a.h>
#include <stdlib.h>
/* Device Fuse Settings */
#fuses HS,NOWDT,NOPROTECT,PUT
/* Device Clock Settings */
#use delay(clock=20000000)
/* Device IO Settings */
#use fast_io(A) /* inputs */
#use fast_io(D) /*inputs */
#use fast_io(E) /*unused, set to all out anyway */
#use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7)
#use i2c(master, scl=PIN_B6, sda=PIN_B7, SLOW)
#define READ_ADDRESS 0xa1
int main(void)
int number = 0;
disable_interrupts(GLOBAL);
disable_interrupts(INT_SSP);
while(1 == 1)
printf("tx i2c \n\r");
i2c_start();
// printf("i2c START Complete \n\r ");
i2c_write(READ_ADDRESS);
// printf("i2c Address Sent \n\r");
number = i2c_read(0);
// printf("number: \%d \n\r", number);
delay_ms(5);
i2c_stop();
printf("i2c stopped, \%x \n\r", number);
SLAVE CODE
#include <stdlib.h>
#use fast_io(B) /*inputs */
#use i2c(slave, scl=PIN_B6, sda=PIN_B7, address = 0xa0, SLOW)
#byte PORTA = 5
int main(void)
int temp = 0;
delay_ms(80);
set_tris_a(0);
while(1 == 1)
i2c_write(0xF0);
SOrry for putting entire code up but we really are stuck!
Original Post ID: 10463 |
Tomi Guest
Re: i2c failure |
Posted: Mon Jan 06, 2003 10:45 am |
I don't think that a bitbanged I2C slave could work anyway.
Use the HW I2C and the interrupt-driven mechanism. I use something like this to send out a 10-byte answer for a simple read:
#byte SSPCON1= 0x14
#byte SSPBUF = 0x13
#byte SSPSTAT= 0x94
#define RECORDSIZE 10
char SSP_data[RECORDSIZE],phasecnt;
#int_ssp
void ssp_isr()
if (!bit_test(SSPSTAT,5)) {
phasecnt = 0;
if (phasecnt < RECORDSIZE) {
SSPBUF = SSP_data[phasecnt];
bit_set(SSPCON1,4);
phasecnt++;
if (phasecnt == RECORDSIZE) {
// end of transmission
enable_interrupts(INT_SSP);
Original Post ID: 10465 |
