MRF49Xa
championx
MRF49Xa
PostPosted: Mon Jun 17, 2013 6:26 am     Reply with quote
Hi! is someone using the MRF49Xa or the Si4421?
I have a module but i don't have the driver for it.
Could someone share his code?
thanks
RF_Developer
PostPosted: Mon Jun 17, 2013 9:32 am     Reply with quote
If no one else has a driver then I suggest you write one and test it and then share it with everyone else.
asmboy
PostPosted: Mon Jun 17, 2013 11:57 am     Reply with quote
I have a module
TWO modules would be the minimum for development.
you should note that in order to make a working system from a PAIR of these, you need to have some circuit skills PLUS coding ability.
This is a project suitable ONLY for an experienced engineer, IMHO.
personally , i would begin with Microchip AN1252
found HERE:
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1824&appnote=en545176
championx
PostPosted: Tue Jun 18, 2013 6:51 am     Reply with quote
Thaks for oyur reply.
Yes, i have programming and circuit designing skills. I have 2 modules designed by me using the Si4421 (same as the MRF49xa).
I was just asking if someone have a driver just to make things faster.
I will code my own driver.
Thanks.
