uart pic 18F4620
Knight_FlyCn
uart pic 18F4620
PostPosted: Sat May 18, 2013 2:14 am     Reply with quote
I want function send data to port TX of Uart. I used pic 18f4620. who can help me.
/* _CPUDIV_OSC1_PLL2_1L,  // Divide clock by 2
   _FOSC_HS_1H,           // Select High Speed (HS) oscillator
   _WDT_OFF_2H,           // Watchdog Timer off
   MCLRE_ON_3H            // Master Clear on
#include <RFD.h>
#include <stdlib.h>
#include "def_18f4620.c"
#include "slave_1_tx_rx.h"
#define SPI_MODE_0  (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#ifndef FREQ
#define FREQ 4000000   /// 4Mhz
#define baud 9600
#define spbrg_value (((FREQ/16)/baud)-1)
int StartFlag = 0;
int StopFlag = 0;
char array[12];
char i = 0;
#bit CS     = 0xF80.4
#bit RST    = 0xF82.2
#bit INT_   = 0xF81.0
#bit WAKE   = 0xF82.1
#bit CS_Direction    = 0xF92.4
#bit RST_Direction   = 0xF94.2
#bit INT_Direction   = 0xF93.0
#bit WAKE_Direction  = 0xF94.1
// Command: 0x00: IP request                                                  //
//          0x01: I_AM_LM35                                                   //
//          0x02: I_AM_PIR
INT TEMP;
int adress;
INT VALUE;
INT16 k=0;
const int IP_request=0x00,adress_surport=0x01,ip_surport=0x10;
int I_AM_LM35=0x01;
INT DATA_SEND=0X02;
INT COMMAND;//
INT1 IP_REQUEST_FLAG=FALSE;
SHORT SLEEP_MODE=true;
//!#INT_RTCC
//!VOID NGAT_TIMER0()
//!{  printf("ngat timer0!");
//!   k++;
//!   IF (k>= 1000)
//!   k=0;
//!   SLEEP_MODE=FALSE;
//!   TMR0IF=0;
//!   disable_interrupts(INT_TIMER0);
#INT_EXT
void ngat_RB0()
   temp = read_ZIGBEE_short(INTSTAT); // Read and flush register INTSTAT
   if ((temp&(1<<3))==(1<<3))
      read_RX_FIFO();
      COMMAND =DATA_RX[0];
      SWITCH (COMMAND)
      CASE ip_surport:
                  ADRESS=DATA_RX[1];
                  rfd_ADDRESS_short[1]=adress;
                  IP_REQUEST_FLAG=TRUE;
      BREAK;
   void uart_init(void)
         SPEN =1;
         SYNC = 1;
         BRGH = 1;
         SPBRG = spbrg_value;
         CREN =1;
         GIE =1;
         PEIE =1;
         RCIE =1;
    void interrupt_RXR()
         RCIF = 0;
            if(RCREG == 0X02)
                  StartFlag = 1;
            if(StartFlag == 1 && RCREG != 0X03)
                  array[i] = RCREG;
                  i++;
            if(RCREG == 0X03)
                  array[i] = '\0';
                  StopFlag = 1;
                  i = 0;
TRISC0=TRISD3=0;
TRISC7=1;
TRISC6=0;
   CS_Direction   = 0;     // Set direction to be output
   RST_Direction  = 0;     // Set direction to be output
   INT_Direction  = 1;     // Set direction to be input
   WAKE_Direction = 0;     // Set direction to be output
   Delay_ms(5);
   setup_spi(SPI_MASTER | SPI_MODE_0 | SPI_CLK_DIV_4);  // Initialize SPI module
   pin_reset();                              // Activate reset from pin
   software_reset();                         // Activate software reset
   RF_reset();                               // RF reset
   set_WAKE_from_pin();                      // Set wake from pin
   set_long_address(ADDRESS_long_1);
   set_short_address(rfd_ADDRESS_short);       // Set short address
   set_PAN_ID(PAN_ID);                     // Set PAN_ID
   init_ZIGBEE_nonbeacon();                  // Initialize ZigBee module
   nonbeacon_device();
   set_TX_power(31);                         // Set max TX power
   set_frame_format_filter(1);               // 1 all frames, 3 data frame only
   set_reception_mode(1);                    // 1 normal mode
   enable_int();
   pin_wake(); // Wake from pin
   uart_init();
      if(StopFlag == 1)
            StopFlag == 0;
            StartFlag == 0;
            for(i=0; i <=13; i++)
               array[i]=0;
            i=0;
Now i want send data in array to TX. So send to PC. I want function " uart_write"
Thinh
PostPosted: Sat May 18, 2013 4:00 am     Reply with quote
putc()
To format the data printf()
Get rid of your uart_int function. This is already done for you by #use RS232.
Look at ex_sisr.c for how to handle a receive interrupt.
PostPosted: Sat May 18, 2013 5:19 am     Reply with quote
also
always add 'errors' to the use rs232(...options...) when using the hardware UART to avoid it from 'locking up' due to framing errors.
and..
code like 'temp&(1<<3))==(1<<3) is 'messy'.
you should 'play computer', see what 1<<3 is and use that number instead. It saves processor time trying to figure out what it is TWICE and you'll be able to debug problems better.In fact if you define a variable say 'errorbit' or whatever it really is, then tomorrow or next week you'll KNOW what is going on.
hth
jay
