salih_yavuz
| please help me |
Posted: Fri May 17, 2013 5:29 am |
hello everybody,
i would like to ask a questıon about my project if anyone help me for it ı will be pleasure..
my problem is that ı wrote my program on the ccs c compiler and when i compile it there is no errors and then when ı upload to pic my hex. file i cannot see anything on the isis program
ım using 1 lcd , keypad 2 pieces stepper motor but it does not work i didnt understand anything which reason may it happen _? |
branko
| Re: please help me |
Posted: Fri May 17, 2013 6:20 am |
Post your code. Without seeing your code nobody can help. Also post your Circuit. Maybe you have not pulled MCLR high. _________________ Regards
Branko |
Mike Walne
Posted: Fri May 17, 2013 6:35 am |
This is NOT an ISIS help forum.
Proteus / ISIS is busted.
Use REAL hardware, show us your code and schematic then we can help.
Mike |
Joined: 01 Jul 2010 Posts: 9619 Location: Greensville,Ontario
Posted: Fri May 17, 2013 6:37 am |
It is unlikely that anyone here will help you with your ISIS/proteus problem.
The 'regulars' here are well aware that it is full of bugs,errors and faulty DRCs and none of us have the time to rewrite ISIS!
As mentioned, show us your CCS code and we can help with that.Also tell us which compiler version you are using,and which PIC( though that will be in the program).
Since you didn't get any errors, it sounds likely to be a coding issue.
hth
jay |
