mobrien99
				| CCSLOAD Won't load .hex file with #import included |
				 Posted: Mon Apr 15, 2013 9:47 am     |
				I have a combined .hex file with an #import of my bootloader.
All works well when I load it with ICD Debug loader. Bootloader comes up, sees the application is there and transfers control to it.
When I load it with CCSLOAD, it doesn't work because it appears that the application code gets loaded but the bootloader (#imported code) including the revectored interrupt locations doesn't. Any ideas?
The #import line:
#import(FILE=bootloader.hex,HEX,RANGE=0:0x1BFF)
CCSLOAD version: 4.039
Compiler: 4.138
Target: 18F67J11 |
