Add clock cycle to SPI
fastlink30
PostPosted: Wed May 01, 2013 12:26 pm     Reply with quote
#use SPI (MODE=0,FORCE_HW,BITS=8,MSB_FIRST)
this make 8 clk cycle to get/put data on spi interface, i need 1 clk cycle (start condition), send 8 bit (8 clk cycle), and 1 clk cycle (stop condition)
is possible make this or i must make my routine that emulate SPI?
thanks
PostPosted: Wed May 01, 2013 12:31 pm     Reply with quote
simple enough to make your own software SPI but we'd like to know WHAT SPI device you're using that needs start-data-stop format?
That 'format' sounds more like good ol' 'sync'ed RS-232' data(8-n-1) not SPI, though it could also be an I2C device.....
Please tell us what the device is, maybe a link to the datasheet !
hth
jay
fastlink30
PostPosted: Wed May 01, 2013 12:41 pm     Reply with quote
http://www.ti.com/litv/pdf/slos743f
this device can work with slave select or not, without, need start/stop condition on spi (look 5.9.5.1 on datasheet)
alan
PostPosted: Wed May 01, 2013 1:44 pm     Reply with quote
Your start condition is when you take SPI ENABLE low and stop condition is when SPI ENABLE is high.
fastlink30
PostPosted: Wed May 01, 2013 1:46 pm     Reply with quote
I do not use ENABLE signal, to substitute this signal i need 1 clk cycle before and after I have sent bits.
Is required by the chip that i use.
PostPosted: Wed May 01, 2013 4:21 pm     Reply with quote
The hardware SPI can't do this.
Software SPI, can be told to use 10 bits, and then you would need to copy the byte to send into a 16bit variable, and rotate this one bit.
You can also do this with the USART (if your chip has one), but on most chips only in half duplex. However the chip does only seem to only ever receive or send, so with an external logic gate this could be made to work.
However using SS, is easier, and likely to be much more reliable (it'll recover if a bit is lost, which the version without SS won't).....
asmboy
PostPosted: Wed May 01, 2013 6:22 pm     Reply with quote
i had the misfortune to work with the 7960 a while back
honestly - I ended up using a 40 pin pic , and the PARALLEL method of
control for that part
you will need to bit bang the SPI mode- and since you are implicitly a slave,
( for reading)
also -
you will need to use INTs with a pin on port B to handle the IRQ function..
fastlink30
PostPosted: Thu May 02, 2013 2:30 am     Reply with quote
to ttelmah: i have implemented my routine for dedicated SPI, in the next revision of the PCB i want use the SS (make the things more 'standard')
asmboy: why misfortune? INT is already connected with port that handle IRQ function Wink
thanks to all the people
asmboy
PostPosted: Thu May 02, 2013 6:46 am     Reply with quote
All to the good - it was not clear that you understood this key point.
Happy for your success.
