Capacitive Button with PIC16F1934 TOUCHDATA Problem
eflatun
PostPosted: Wed Mar 27, 2013 6:36 am     Reply with quote
I'm new on PIC and CCS C but on the other hand eager about this. I would like to use the mtouch system but i couldn't. I have got some problem with CCS C because when i did compile this code i have got 2 warnings like this.
"Variable never used: TOUCHPADSTATUS
Variable never used: TOUCHDATA"
The compiler version is V4.114
The PIC I am using is 16F1934
#include <CapSensButt.h>
#USE TOUCHPAD (PIN_B0='A')
#FUSES ECH
#FUSES WDT_SW
#FUSES NOPUT                    //No Power Up Timer
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOCLKOUT
#FUSES NOVCAP
#FUSES PLL
#FUSES BORV19
#use delay(clock=8000000)
void main(void){
   setup_lcd(LCD_DISABLED);
   char c;
   TOUCHPAD_STATE(1);
   c = TOUCHPAD_GETC();       //will wait until one of declared pins is detected
                                //if PIN_B0 is pressed, c will get value 'A'
   if(c=='A')
   output_high(PIN_A0);
   while(touchpad_hit());
What should i do ?
Whats my fault ? Could u help me pls ?
Thanks alot. Have a nice day.
PostPosted: Wed Mar 27, 2013 7:21 am     Reply with quote
Nothing.
They are just warnings. The same applies when you add 'ERRORS' to #use rs232. The functions return extra data 'in case' you want it. The compiler warns you if you don't use this, but there is nothing wrong with not doing so.
