Strange CAN ID Behaviour on multiple ID's
Uncle Fungus
PostPosted: Wed Mar 20, 2013 4:34 am     Reply with quote
Compiler PCH 4.121
PIC 18F26K80 and 4580
I am having a strange issue when transmitting 2 messages on to the CAN bus (each with a different ID).
"Most" of the time the data transmits fine, approximately every 26th transmission though, there is a "BLIP" in the transmitted data - but not allways!!
The Code is designed to transmit 2 CAN messages. Each message is transmitted every 2mS, with 1mS between different ID's. This is the Spec, and I can't change it because of the software the other end receiving the message.
Thinking there was a bug in my compiler, I even wrote in Assembler, but with the same result, making me think there is some sort of hardware issue with the device. I then compiled the code to run on a PIC18F4580, with the same result, so it must be me??!!
If I don't alternate the CAN ID, between messages all is well, but I need 2 ID's to get the data out.
To simplify the code I created a 16-bit value which increments by 60 every CAN transmission - It should be a straight line, but, it isn't. If the value is a constant, then there are no Blips allmost as if the CAN transceiver is shifting the data out incorrectly - but why only when I use 2 ID's??!!
   //Loop indefinately
//      while(125>Get_Timer0());//wait for 1mS 64MHz CLK /128 TMRO0
      while(78>Get_Timer0());//wait for 1mS
      Set_Timer0(0);
      //Get some data ready to pass to the CAN function
      ADCVal[0]=ADCVal[0]+60;
      ADCData[1]=make8(ADCVal[0],1);
      ADCData[0]=make8(ADCVal[0],0);
      //decide which 4 channels to transmit
      if(TX1_4==0)
         TransmitCAN1(tx_id,ADCData);
         TX1_4=1;//change for next time
         TransmitCAN1(tx_id+1,ADCData);
         TX1_4=0;//change for next time;
AND
//Transmit the Data of the required channel
void TransmitCAN1(unsigned int32 ID,unsigned int8 CANArray[8])
   int i;
   out_data[0]=CANArray[1];
   out_data[1]=CANArray[0];
   out_data[2]=0;
   out_data[3]=0;
   out_data[4]=0;
   out_data[5]=0;
   out_data[6]=0;
   out_data[7]=0;
//Transmit the CAN Data
   //ensure txbuffer is empty
   if(can_tbe())
       can_putd(ID, out_data, tx_len,tx_pri,tx_ext,tx_rtr); //put data on transmit buffer
andrewg
PostPosted: Thu Mar 21, 2013 1:59 am     Reply with quote
Define "BLIP". Is it missing data or corrupted data? If corrupted, what sort of values are being received? Data corruption should be rejected by the receiver due to CRC mismatch. Can you set up a second receiver on the bus to output all packets?
Andrew
gpsmikey
PostPosted: Thu Mar 21, 2013 3:15 pm     Reply with quote
You would not, by chance, be getting hit with an interrupt in the middle of sending the message would you ? Especially with any kind of software uart, interrupts can cause very strange things if they happen when you don't expect them (which is usually when they happen right?)
mikey
mikey
