Problem with pointers
monsun
PostPosted: Thu Mar 21, 2013 2:11 am     Reply with quote
Sometimes i have problems with big arrays and pointers:
for example when i use it this way everything is allright:
float example(float *something_external)
int8 i;
float something;
for(i=0;i<10;i++)
something+=*something_external;
something_external++;
return something;
BUT when i use it this way sometimes it makes some problems
int8 i;
float something;
for(i=0;i<10;i++)
something+=*(something_external+i);
return something;
Any ideas?
PostPosted: Thu Mar 21, 2013 2:20 am     Reply with quote
Incorrect syntax.....
You want.
something+=(*something_external)+i;
You are saying to add 'i' to the pointer, _then_ take the contents of this. Effectively treating it as an array, so
something+=something_external[i];
monsun
PostPosted: Thu Mar 21, 2013 2:44 am     Reply with quote
Ive thought that something_external[i] is equal to *(something_external+i) using pointers??
PostPosted: Thu Mar 21, 2013 3:15 am     Reply with quote
OK. So you do want to use it as an array?.
Question then is compiler version and chip???.
If you want to use it as an array, then 'yes' this is right, _but only if you are on a modern compiler_. Historically the older compilers did not increment pointers correctly, treating their size as '1', whatever they pointed to.
There were also problems on particular chips when you crossed page boundaries.
