lighty
Posted: Tue Jan 29, 2013 6:45 am |
This question might seem odd but I'm coming from ANSI C compliant compiler and I'm trying to understand CCS syntax.
For example is this expression
Code: | output_bit(ONE_WIRE_PIN, shift_right(&data,1,0)); // set output bit on 1-wire |
the equivalent of this one?
Code: | data >>= 1;
data &= 0x7F;
ONE_WIRE_PIN = data; |
Posted: Tue Jan 29, 2013 4:33 pm |
The easiest way to see what the compiler is doing, is to make a small
test program, compile it and look at the .LST file. Then add comments
to the ASM code to describe what's happening:
..... output_bit(ONE_WIRE_PIN, shift_right(&data,1,0));
0032: BCF STATUS.C // Clear the Carry bit
0034: RRCF data,F // Rotate data right, so Carry = LSB of data
0036: BC 003C // Jump to 003C if Carry bit = 1
0038: BCF LATB.LATB0 // If Carry = 0, set the pin = 0
003A: BRA 003E
003C: BSF LATB.LATB0 // If Carry = 1, set the pin = 1
003E: BCF TRISB.RB0 // Set TRIS on pin = output
Test program (compiled with vs. 4.140):
#include <18F4520.h>
#fuses INTRC_IO,NOWDT,PUT,BROWNOUT,NOLVP
#use delay(clock=4M)
#define ONE_WIRE_PIN PIN_B0
int8 data;
RF_Developer
Posted: Wed Jan 30, 2013 3:02 am |
lighty wrote: | This question might seem odd but I'm coming from ANSI C compliant compiler and I'm trying to understand CCS syntax.
Code: | data >>= 1;
data &= 0x7F;
This is NOT an ANSI compliance issue. It's an understanding CCS library functions issue. CCS C can be set to be (mostly) ANSI compliant, and you'll still have those functions. They are simply library functions implemented by the compiler as are pretty much essential for all embedded programming. Realistically there cannot be any totally ANSI compliant and therefore fully portable embedded C code. There will always be some hardware dependence, which requires some sort of processor or hardware family-specific non-portable code of some kind; for example pin I/O. CCS C tries, generally successfully, to abstract all that and provide a set of library functions and the like that cover almost all PIC processors.
The answer to your question however is no. The equivalent, assuming data was a byte, which is what the shift function call suggests, would be:
ONE_WIRE_PIN = (int1)(data & 0x01);
data >>= 1;
This is because the function shift_right, shifts the single byte pointed to by the address of data by one bit, shifting in a zero - which is a don't care - and returning the old LSB. The reason this function is provided is that it maps far better onto the opcodes provided by the PIC hardware than any generic version such as ANSI C. In other words its a processor specific optimisation.
This code is unlikely to be on its own, it only makes sense as part of a loop, probably through all eight bits of a byte. Though you clearly are unlikely to code it that way as output bit with a variable is inefficent. Much better to do something like:
if (shift_right(&data,1,0))
output_high(ONE_WIRE_PIN); // set output bit on 1-wire
output_low(ONE_WIRE_PIN); // set output bit on 1-wire
RF Developer |
Posted: Wed Jan 30, 2013 3:22 am |
The 'equivalence' question is also missing another thing. 'ONE_WIRE_PIN', is just a number. It is not physically the pin, and can't be written directly. If you read the manual for 'output_bit', it tells you:
"The actual number is a bit address. For example, port a (byte 5 ) bit 3 would have a value of 5*8+3 or 43"
So using the example number above, "ONE_WIRE_PIN = data;"
would translate as "43 = data;".
Duh......
